Old 18-01-2006, 02:21 PM   #1 (permalink)
Default FAT32 to NTFS....
well, i have a 40gb hard disk with 10 partitions. except for G:, F: and C: everything is ntfs. I have important data in these three partitions so i can't format. how can i convert it into ntfs without formatting? also, what is a dynamic drive? please help...
Dumbledore is offline
Old 18-01-2006, 02:31 PM   #2 (permalink)
9437077259
go4saket's Avatar
Search buddy... Anyways, here is the link...
http://www.thinkdigit.com/forum/view...907&highlight=
go4saket is offline
Old 18-01-2006, 04:08 PM   #3 (permalink)
::cyborg::'s Avatar
WHAT OS U HAVE
IF U HAVE XP THEN
DUMBLE DORE LIKE UR DATA IS IN D DRIVE AND U WANT TO MAKE DRIVE D: NTFS THAN DO ONE THING TRANFER THE FILES TO OTHER DRIVE AND THEN FORMAT D: TO NTFS WITHIN WINDOWS AND THEN TRANFER BACK THE FILE TO THE D: DRIVE
::cyborg:: is offline
Old 18-01-2006, 05:01 PM   #4 (permalink)
dIgItaL_BrAt's Avatar
@cyborg:would ya mind not typing in caps,it's considered shouting.
dIgItaL_BrAt is offline
Old 18-01-2006, 08:48 PM   #5 (permalink)
C.A.
abhishek66's Avatar
i guess what cyborg said is the best solution.... i did the same thing to convert my fat partions to ntfs
abhishek66 is offline
Old 18-01-2006, 09:15 PM   #6 (permalink)
there is no necessity for formatting the hardisk for partition format changes!!! so cyborg and abhishek, since he has asked for a solution which doesnt need formatting, i wud recommend u ppl to provide with such a sol. if u knew.
Originally Posted by vijay_2787
go to commandpromt
and type help convert
to get more necessary instructions.
just go to command prompt
and type
convert e: /fs:ntfs
to convert to ntfs... u can add other necessary options if necesary by finding the options as told above.
OR
u can use norton partition magic and convert in minutes. there is no need to format. pls donot recommend it as a method.
/legolas
legolas is offline
Old 18-01-2006, 10:59 PM   #7 (permalink)
would somebody mind answering his second question? What is a Dynamic drive? frankly, i don't know myself...
P3PoweR is offline
Old 18-01-2006, 11:20 PM   #8 (permalink)
cybermanas
Posts: n/a
There is no need to format to convert to NTFS.You can use Partition Magic to convert the partition to NTFS without any data loss.
Old 19-01-2006, 12:18 AM   #9 (permalink)
reg. "dynamic drive" explain a little more reg. the context u are needing an explanation for?
/legolas
legolas is offline
