Old 17-01-2006, 10:02 PM   #1 (permalink)
Default Logical disk manager problem
hi
In the device manager under system device my computer is showing an exclamation mark before Logical disk manager and in its properties it is showing this
"Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)"
becoz of this i cannot use disk manager in administrative tools
it says
"unable to connect to logical disk manager service"
"dependency service or group failed to start"
is it a problem?.....if yes then how do i solve this problem
PLZ HELP
hippi is offline
Old 18-01-2006, 05:15 AM   #2 (permalink)
yrana2002's Avatar
The Logical Disk Manager Service in your pc has been disabled.
Type services.msc in Run
In the dialog box, select Logical Disk Manager & ensure it is set as Manual. If not,
right click it and click on properties and change Startup Type to Manual.
Similarly, see to it that Logical Disk Manager Administrative service, just below to it is set to manual as well. This service depends upon the previous one to function.
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 18-01-2006, 07:21 PM   #3 (permalink)
i tried it but it says
"logical disk manager service is started and then stopped ,some service stops if they dont have any work to do"
so exclamation mark stays on....
and i cant use disk manager...
plz help
P4 1.6Ghz,768MB SDRAM , on i845 mobo ,Philips 150S4 lcd on sis 315 Pro with 128MB VRAM ,40GB ATA100 5.4K rpm HDD,wifi enabled.hate sound card
hippi is offline
Old 18-01-2006, 08:06 PM   #4 (permalink)
yrana2002's Avatar
I got the error:
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Try these options:
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Click Uninstall, and then click Scan for hardware changes to load a usable driver.
Restart the computer in Safe Mode, and then select Last Known Good Configuration.
This rolls back to the most recent successful registry configuration.
