Old 16-01-2006, 06:01 PM   #1 (permalink)
Default How to change the IE Useragent
Hi
I used xsetup to change the IEW useragent but it is not working.
Then I manully changed all entering in registry but it is showing the same default useragent.
Can anyone Know that how can i changed the useragent
I have .net framework 2 installed
OS is winxp
Thanks
minniawochat is offline
Old 16-01-2006, 07:26 PM   #2 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
You can change the user-agent with proxomitron
chesss is offline
Old 16-01-2006, 10:30 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
May be it help u:
Win Guides
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
