24-10-2004, 08:58 PM
You can use this tool:
FlashDigger Plus v. 3.46
Direct Download Link:
http://www.flashdig.com/download/beta/flashdigger.zip
Software Description:
Explores Flash (SWF) files, extracts and updates text, graphics, sound and actions. Graphics can be exported in JPEG, PNG and BMP format. Sounds are saved in MP3 or WAV.
You can explore SWF file listings, change scene sizes and frame rates, remove tags or frames, add, remove or modify actions, change object placement, change a hyperlink associated with a button object, apply a hyperlink to a movie or to any rectagular area of its scene (create a transparent button), create and update graphics, remove objects from a scene, update a button or a frame sound, apply a soundtrack to a movie or to any clip, and remove a soundtrack from a movie with an immediate preview of the results.
Most advanced features of the latest version are:
- Shapes Import/Export
- Buttons Import/Export
- ActionScript Import/Export
Thus you can export an object from one SWF file and then import it into another SWF file and place imported object to the movie scene. Buttons are imported together with all their attributes (related shapes and button actions).
Exporting objects you can create a library of reusable objects without their manual recreation for each movie.
You can also compress or decompress, protect or unprotect SWF files, import SWF files from projectors (EXE), and convert SWF files to EXE with a set of extended options.
Also included are: an MP3 encoder, a sound uncompressor, and a sound MP3 recorder.
FlashDigger Homepage:
www.flashdig.com
Source and More Info
visit swf2fla.biz ,they convert swf to fla for u.
Visit above source for more info
No Mercy, No Limits.
