Hi All,
I have this confusion. The netstat command sometimes shows host and foreign addresses as 127.0.0.x ( random) mostly when
using limewire. Just netstatted and got the following addresses
Proto Local Address Foreign Address State
TCP 127.0.0.1:1120 127.0.0.1:1121 ESTABLISHED
TCP 127.0.0.1:1121 127.0.0.1:1120 ESTABLISHED
TCP 127.0.0.1:1151 127.0.0.1:1153 ESTABLISHED
TCP 127.0.0.1:1153 127.0.0.1:1151 ESTABLISHED
TCP 127.0.0.1:1160 127.0.0.1:1161 ESTABLISHED
TCP 127.0.0.1:1161 127.0.0.1:1160 ESTABLISHED
^^ Filtered.... Now these Foreign addresses are confusing.
The moment I opened limewire Zone alarm authenticated and gave source IP as 0.0.0.0 port 45184 ( no probs with port) but how
can the source ip be 0.0.0.0 ?
Now the confusing s*it. I access my Internet thru Cable, LAN. Just netstatted randomnly and there was request sent to ip
192.168.0.231 Now since this ip is local ip and my network is completely different, I am really confused and curious so as to
what is this. Here is the screen shot.
<snipped> for security reasons
===Audio Problem===
For some very good reasons I dont know my two left speakers of Intex 2000 watts woofers gives low output sound compared to
right. Did try every setting from control panel, dint help.
While playing a song in media player, if I open real player, it gives "In use...." error and I have to unistall and reinstall
audio drivers from device manager to continue. This didnot happen earlier.
===Mouse Problem===
I did bring this up earlier. I have LG Optical mouse which was not working properly earlier, no it is. The issue is it is too
sensitive. 7/10 times it double clicks for single click, this is getting annoying. I adjusted the sensivity from control
panel but i may be missing something.
===DAP Problem===
Now this is real strange. I use DAP Premium 7.0.1.3 The download speed options are like listed below
Normal Speed.
Accelerated Speed.
High Acceleration Speed.
Super Acceleration Speed.
Extreme Acceleration Speed.
The major difference is between selected download sources. For last it downloads from 10 locations, 1 above its 7 and so on.
Now when I select Extreme acceleration speed, it only downloads from 4 locations where as "Super acceleration" has 7 sources.
I remember extreme acceleration downloaded from 10 locations. Help!!!
===MSN Live===
I got invited for MSN live beta ( thanks to Tuxian
) everything went smoothly except that there are no buddies in my list
now. I had 22
Plz help.
===File association issue===
Normally when we try to open a file with no extention, it asks us "choose a program to open" but in my case it opens with
Notepad directly, this is pain in....
Only this as of now
I may be forgetting some...Plz plz plz help
