15-01-2006, 09:10 AM
Virtual Dub Output File Size (~30GB) [solved]!!
I tried to convert a 700 MB VCD into avi using Virtual Dub, but the output file was ~30GB in size!!! How to decrease the size???
15-01-2006, 10:07 AM
You probably converting it into uncompressed avi, use a free mpeg4 codec like xvid and convert to that in full processing mode.
15-01-2006, 11:32 AM
can u explain a little bit more on it ...urgent yaar...what to download and what to do ??
\"I\'ve Got A Great Ambition To Die Of Exhaustion Rather Than Boredom.\"
\"Where Would You Go When You Can\'t Forget The Past And You Don\'t Know The Future.\"
15-01-2006, 12:26 PM
Use a codec like DIVx , Its available on digit CD or DVD 's
15-01-2006, 12:50 PM
Laptoping
Follow what worm has to say, select the audio and video compression and configure according to file size you require. And then hit save as avi.
15-01-2006, 01:14 PM
please tell me can we convert DAT file to AVI through virtualdub ???
if yes please gimme a step by step procedure ?
thanks!
15-01-2006, 02:57 PM
-Metallica
15-01-2006, 02:59 PM
Re: Virtual Dub Output File Size (~30GB)!!
Probably You didn't use any compression codecs and let the Video to remain at Uncompressed.Use an Xvid compression codec for video and Mpeg Layer 3 128Kbps or AC3 5.1 codec for Audio compression.That must do the trick.
@bala4digit:Try this http://www.aoamedia.com/Convert_DAT_to_AVI.htm
OR http://www.videohelp.com/avi2divx.htm
V for Vendetta
15-01-2006, 06:56 PM
i have k-lite mega codec pack, aint that enough??
Shwetanshu Srivastava
15-01-2006, 07:07 PM
Learner
u have not compresses and selected "DIrect stram copy"
just compress it using a codec........
15-01-2006, 07:39 PM
thansk for that alib_i and allwyn
thanks a lot !
15-01-2006, 10:28 PM
Technically It is enough but how to use it in virtual Dub is the point.In Virtual Dub first head out to Video Option and then hit compression and later select the appropriate codec from the List.After this when you save it as .avi file only then will the compression be proper.
V for Vendetta
15-01-2006, 10:44 PM
ok finally got it to work... now tell me some good codecs/filters which i cud use with Virtual Dub
16-01-2006, 08:44 AM
Video Codecs:Xvid Mpeg4 Codec
Above settings guide http://www.doom9.org/index.html?/xvid-vdub-11.htm
Audio Compression:Mpeg Layer 3
V for Vendetta
16-01-2006, 09:02 AM
thnx allwyn
Search this Thread |
