Old 14-01-2006, 07:16 PM   #1 (permalink)
Default Another Problem
When I open my computer>tools I see only 3 options insteed of 4. I cant see the folder option and so I cant see the hidden files and so. Whats the cause of this problem and how to solve it. And thank u for helping my previous problem.
tanmoy_rajguru2005 is offline
Old 14-01-2006, 07:27 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
go to control panel, and view it in the classic style
u will get the folder options there
and incase u r usin a limited a/c, then tht option might have been freezed
vijay_7287 is offline
Old 14-01-2006, 08:24 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Open regedit and nevigate to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer
In right-side pane u'll see a key named, NoFolderOptions, change its value from 1 to 0 or simply delete the key!!!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 14-01-2006, 10:00 PM   #4 (permalink)
I have deleted this key
but no solution.
Old 14-01-2006, 11:05 PM   #5 (permalink)
What version of OS are you using? In some, you have Folder Options available in Control Panel. In some, if you go to Desktop properties (Right click on Desktop and select properties), in the tab with Active Desktop, there is a button for Folder Options...
Arun
sakumar79 is offline
Old 15-01-2006, 01:04 AM   #6 (permalink)
I use windows XP professonal and there is no folderoption icon in my control panel (classic view) .In my friend's comp it is there (same os) but for me it is not there
Old 15-01-2006, 03:28 AM   #7 (permalink)
alib_i's Avatar
but no solution.
Do the same to
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Policies\Explorer
Delete the "NoFolderOptions" from there too.
(Actually I would suggest you to create a "NoFolderOptions" DWORD key and put it to 0 in both places .. that would force this setting)
If nothing works .. try this ..
# Go to C:\Windows\System32 folder
# Rename your "appwiz.cpl" to .. say "appwiz2.cpl"
# Copy your friend's appwiz.cpl into your system32 folder (bring it over in a floppy or something)
Note :
> It's risky .. try at your own risk. Although .. no problem is expected.
> appwiz.cpl contains both add/remove programs and folder options .. hence i'm asking you to replace it with a working file.
alibi
-Metallica
alib_i is offline
Old 15-01-2006, 06:43 AM   #8 (permalink)
Download http://www.kellys-korner-xp.com/regs...deroptions.reg and merge with registry
If that doesnt work, see if these two commands help, from Administrator logon.
Type in Start, Run:
regsvr32 /i browseui.dll
regsvr32 /i shell32.dll
Restart Windows.
Arun
Old 15-01-2006, 01:52 PM   #9 (permalink)
Do the same to
Thank u guys. It solves the problem.
Old 15-01-2006, 04:21 PM   #10 (permalink)
__Virus__'s Avatar
Wohooo alibi thanks for that simple trick to be used for hiding and unhiding folder options
__Virus__ is offline
Old 15-01-2006, 08:04 PM   #11 (permalink)
alib_i's Avatar
'welcome friend !
alibi
-Metallica
alib_i is offline
