Old 14-01-2006, 02:21 PM   #1 (permalink)
Default Critcal Objects found by Ad Aware.
I am using Win XP SP II with all updates along with MS Antispyware, Ad Aware, Spybot, Spywareblaster and Avast antivirus. Now adays when I scan with Ad Aware, it finds two critical objects which is not detected by any other program when scanning. Even after removal by Ad Aware, it is again seen the next time the pc is scanned. Please enlighten me. The following is ths screen shot.
Category:Vulnerability
Object Type:RegData
Location:regfile\shell\open\command "" (notepad.exe %1)
Last Activity:14-01-2006
Relevance:Low
TAC index:3
Commentossible virus infection, REG file extension compromised
Description:General Windows Security Issue. Your system security may be compromised. The specifics of the possible compromised item are listed in the comments section.
V.Prem Kumar.
V.Prem Kumar
janitha is offline
Old 14-01-2006, 10:25 PM   #2 (permalink)
Default Re: Critcal Objects found by Ad Aware.
Somebody pl help
V.Prem Kumar
janitha is offline
Old 14-01-2006, 10:50 PM   #3 (permalink)
usually, this notepad %1 other programs complain it so. and change it to notepad.exe. to my knowledge, there is nothing to worry abt. i dont remember which software, think its system mechanic, it restored that notepad %1 to notepad... u can use similar registry softwares to fix it.
/legolas
legolas is offline
Old 15-01-2006, 08:09 AM   #4 (permalink)
/legolas
Thanks a lot. And you should be correct since it is only recently that I started using 'System Mechanic'. !
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 15-01-2006, 08:12 AM   #5 (permalink)
vignesh's Avatar
System mechanic is really good...
vignesh is offline
Old 15-01-2006, 01:52 PM   #6 (permalink)
Yes, definitely.
V.Prem Kumar
janitha is offline
