Old 23-10-2004, 06:24 PM   #1 (permalink)
Default plz help quite a few probs.
Which r these extensions,and how to use them
.IDX and .SUB
Since I downloaded it frm a vid site may be they r video files.
And 1 more thing How can I play all the video files using 1 mediaplayer I mean is there no place frm where all the codecs can dloaded,And what is the best software to capture streaming media ,not only online radio but other streaming media such as real media.
How can i convert dloaded media into mp3 and other formats.
thanx in advance
Never argue with an idiot ,first he will lower u till his level ,then beat u with his experience.
akitosforever is offline
Old 23-10-2004, 06:31 PM   #2 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Go to fwww.filext.com for infoabout sub and idx files.
Try installing Nimo Codec Pack or see this link :
http://www.google.com/custom?q=codec...D%3A1%3B&hl=en
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 23-10-2004, 10:13 PM   #3 (permalink)
Install Core Media Player for all ur Video related problems......
http://www.free-codecs.com/The_Core_...r_download.htm
For Audio Streaming probs.......
If u have enough space in ur hard drive , use Total Recorder ..it's no audio stream recorder but it records every bit of audio coming out of ur sound card!!! for the link...try googling !!!!!
For changing audio format use dbPoweramp music converter (it integrates to your right click menu)
http://www.dbpoweramp.com/dmc.htm
Shine on ! You crazy diamond !!!
pag_floyd is offline
Old 23-10-2004, 11:19 PM   #4 (permalink)
If you downloaded a .ccd file as well then those .idx and .sub files are probably CloneCD files. look up the faq at Clonecd website (gooogle it
sailendra is offline
