Old 13-01-2006, 11:26 AM   #1 (permalink)
"Technologic"
Apollo's Avatar
Default Free GIF Animator tools?
I'd like to know about free gif animators that do not only create gifs but also has an option for adding effects while jumping one frame to the other.
Thanks.
One great use of words is to hide our thoughts.
Apollo is offline
Old 13-01-2006, 12:01 PM   #2 (permalink)
bala4digit's Avatar
iam not sure about effects but try MICROSOFT GIF ANIMATOR !
\"I\'ve Got A Great Ambition To Die Of Exhaustion Rather Than Boredom.\"
\"Where Would You Go When You Can\'t Forget The Past And You Don\'t Know The Future.\"
bala4digit is offline
Old 13-01-2006, 12:39 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
is it freee???
vijay_7287 is offline
Old 13-01-2006, 01:07 PM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Probably you should ask "Does it exist"???!!
kalpik is offline
Old 13-01-2006, 05:54 PM   #5 (permalink)
bala4digit's Avatar
hmm...i don't know abotu other planets kalpik but it surely does exist in earth....before that post u cud have done a google search...anyways if u are in mars..iam sorry!!
here is the link :http://www.google.com/search?sourcei...T+GIF+ANIMATOR
the facts !! :
Microsoft GIF Animator is a handy tool that allows you to easily create animated graphics. It can produce attractive GIF images that are fully optimized for the web. No code is required. All you need are an initial set of GIF or AVI files, which may be created with any good graphics program. These files can be opened with simple drag and drops from anywhere on the file Explorer.
Microsoft GIF Animator offers a wide range of tools for creating the perfect GIF. By default, the program assigns a 8-bit color palette to each of your images. Microsoft GIF Animator gives you the ability to load your own custom palettes, including a choice between four dither methods. You can also configure the width and height of the animation as well as all frame characteristics. Animation options also let you loop, spin, fade images and add trailing comments. You can also apply transparency background colors. At any point, you can preview a GIF in the built-in animation viewer.
Finished images are saved in the GIF89a file format, which stores the information necessary for flipbook-style animation. Microsoft GIF Animator is free. It's a standalone application that's designed to work with Microsoft's Image Composer. Microsoft Image Animator receives four smileys.
PROGRAM FACTS
Freeware
Version 1.08
Fee/Price
FREE
File Size
1.083M
Requirements
8MB RAM. 2MB HD Space. VGA Video. 80486DX CPU.
Suggested OS
Windows 95. Windows NT. Windows 98.
Old 13-01-2006, 08:20 PM   #6 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
thx for the info BALA
Old 13-01-2006, 08:33 PM   #7 (permalink)
bala4digit's Avatar
always welcome
Old 18-01-2006, 05:05 PM   #8 (permalink)
::cyborg::'s Avatar
ANIMATION SHOP BY JASC SOFTWARE
::cyborg:: is offline
