Old 13-01-2006, 08:56 AM   #1 (permalink)
Default Card Conflicts !!!?
My current System Configuration :-
D865GBF Intel Motherboard
P4 2.8 Ghz Processor with HT
512 Mb RAM DDR
80 Gb Samsung Puma Harddisk
Windows XP Professional v5.1.2600 with SP2
Earlier I had A Creative 4.1 Sound Card (Model Number- CT4750)
and an ASUS G-Force v9400 Magic Graphics Card too...
One fine day..the monitor wouldn get switched on...no matter what i did...the little green light just kept blinking.So i called my local system service fellow and he came and removed both the sound and graphics card...said they were in conflict...now my system works fine..
Does that mean that both of those cards are useless now? I had no problem for close to a year with both the cards on my system...why did the problem appear suddenly?
Any idea anybody...I have a feeling that lots of people have faced this problem with the monitor in the recent past...a lot of my friends scattered across india have mentioned the same problem to me...
Forgiveness is the fragrance that a violet sheds on the heel that crushes it. To Forgive calls upon your love, to forget calls upon your strength.
anna_don is offline
Old 13-01-2006, 09:09 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
did made any BIOS update or any BIOS change.?? just plug those cards back in... & then try to explorer the option in the BIOS...
reffer to this page...
http://www.intel.com/design/motherbd..._inst.htm#15.5
make sure when u plug the AGP card or the sound card the onboard vedio or sound is of!!...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 13-01-2006, 09:35 AM   #3 (permalink)
Thanks Saurav...I have this gut feeling that the reason for the problems is what u say it is...i'll correct it and let u know...
thanks a million
anna_don is offline
