Old 13-01-2006, 08:47 AM   #1 (permalink)
dinesh_mettur's Avatar
Default I CANT SURF THE NET ( PAGE CANNOT BE DISPLAYED)........
IAM USING WINDOWS MEDIA CENTER EDITION ,I'M USING BSNL DIALUP
ISP FOR SURFING THE NET SUDDENLY I CANT BROWSE THE NET, IF I ENTER ANY SITE IN THE BROWSER (FIREFOX,IE) IT DISPLAYS THAT
PAGE CANNOT BE FOUND ,IF I RESTORE MY SYSTEM TO EARLIER
CONDITION I'M ABLE TO BROWSE THE NET !!!! I THINK MY SYSTEM IS
AFFECTED WITH SPYWARE I TRIED SPYBOT TO SEARCH THE SPYWARE
BUT STILL THE PROBLEM PERSISTS...
MY SYS CONFIG AS FOLLOWS
INTEL P4 2.60 GHZ,256 MB RAM, 845 CHIPSET MDB ,
RINNGING WINDOWS MCE......
IAM NOT USING ANY ANTIVIRUS
SO PLS HELP ME TO FIX MY PROBLEM AND ALSO SUGGEST ME
ANY GOOD SPYWARE AND ADWARE BLOCKING TOOL[/b]
dinesh_mettur is offline
Old 13-01-2006, 09:19 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
u should use one...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 13-01-2006, 10:23 AM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
try usin Zone Alarm pro
vijay_7287 is offline
Old 13-01-2006, 09:13 PM   #4 (permalink)
String Phreak
mediator's Avatar
Default Re: I CANT SURF THE NET ( PAGE CANNOT BE DISPLAYED)........
Yea I encountered this problem many a times.
The problem might be bcoz of
1. MTNL server is down
2. Virus or a trojan corrupted ur net settings
Solution
1. Try to ping ur rouer "Ping 192.168.1.1". If it gives response then its probably ur Mtnl server down. Power down ur PC completely and restart and check again!
2. It might also be ur DNS corruption go to command and type "ipconfig /flushdns","ipconfig/renew","ipconfig/release" !
3. If ping doesnt work ...then ur configuration might be corrupted!
go to command and type "ipconfig/all"....If it doesnt show any info then goto ur Net connection icon in ur network connections.Right click it and fill in the static ip gateway and alll i.e Manual configuration! Check again after restart! If it works stay with it or switch back to automatic configuration again!
This shuld solve ur problem!
mediator is offline
Old 13-01-2006, 09:14 PM   #5 (permalink)
phatratt's Avatar
For anti-virus=AGV 7.0.its free
Firewall=Zone Alarm
Anti-Spyware=Microsoft AntiSpyware,its fast and efficient in busting spywares.
Adware/pop-up blocker/bannerblocker/spam hunter=All in one secretmaker 4.2.4,Its free.
Since u able to browse if revert back using system restore.I thing your modem setting must have been messed up.Else,browser could have been corrupted or infected by spyware.Also clear all the cookies,temporary internet files,etc.
phatratt is offline
Old 13-01-2006, 09:17 PM   #6 (permalink)
phatratt's Avatar
Solution
Dude,Mr.Dinesh is using a BSNL DIAL-UP not MTNL broadband.
phatratt is offline
Old 13-01-2006, 11:40 PM   #7 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
Please dont use Caps. it looks u r shouting.
n00b forever...
~Phenom~ is offline
Old 14-01-2006, 04:18 PM   #8 (permalink)
String Phreak
mediator's Avatar
ok sory 4 dat...definitely a spyware then!
mediator is offline
Old 15-01-2006, 08:13 AM   #9 (permalink)
vignesh's Avatar
Use Avast its free and its really good..
For firewall use Zone Alarm..Even the basic should do and
for adware use Spybot or Adware...
vignesh is offline
Old 19-02-2006, 03:04 PM   #10 (permalink)
sujeet2555's Avatar
any spyware should have changed your computer's host file.you should use winpatrol to revert to your original host file.that should works !
s.k.
sujeet2555 is offline
Old 24-02-2006, 12:13 AM   #11 (permalink)
::vicky::'s Avatar
norton and avast quick heal in a combo provides excellent protection but system bcomes very slow
::vicky:: is offline
