12-01-2006, 10:50 PM
Help needed in upgrading
I m currently using a P IV 1.6 GHz processor with 845 mobo & 384 mb sd ram. thinking of buying an AMD processor with suitable mobo and ram fro around 10k. Can someone suggest the proper processor, mobo and ram to go for...AMD processor ofcourse.........also the mobo should support my modest IDE hard drives!!!!!!!!!!!!!!
12-01-2006, 11:45 PM
SNIST Screamer !!
i think this should be in the hardware section
anyways,
go for AMD athlon64 2800+
mobo - Msi-rs48m2-il
RAM - Hynix DDR400 - 512mb
u will get all this for abt 12k
and they are definitely worth the money
13-01-2006, 04:16 PM
thanx for the help buddy!!!!!!!!! but does this motherboard have onboard graphics???????
If u dont know, dont guesss.... ASK!!!!!!!!!!!
13-01-2006, 05:38 PM
SNIST Screamer !!
yes it does, and is the best in onboard graphics category
13-01-2006, 06:00 PM
if you play games ....and u want them in good graphics...better go for a mobo that supports PCIe cards ...easy for future upgrades !!!
\"I\'ve Got A Great Ambition To Die Of Exhaustion Rather Than Boredom.\"
\"Where Would You Go When You Can\'t Forget The Past And You Don\'t Know The Future.\"
13-01-2006, 07:28 PM
But the mobo that vijay_7287 suggested has both onboard graphics as well as PCIe slot for future expansion.
V.Prem Kumar
V.Prem Kumar
13-01-2006, 07:36 PM
oh...sorry..i din't know that though !
13-01-2006, 09:03 PM
String Phreak
Hey 1.6 Ghz is prety Ok , why r u upgrading? There's not much of a difference between startup time of 2.6 Ghz and 1.6 Ghz PC!
If u maintain ur PC well u'll get tremendous response from ur PC!
13-01-2006, 09:08 PM
With the upcoming high-end extreme graphical & system stressing games like HL2 or Halo, etc, its always better if you have 768MB or 1024MB RAM,
& better if you have a PCI graphics card than the onboard one, like said before, better for upgrades & lesser limitations
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
14-01-2006, 11:15 AM
thanx all of u for the replies!!!!!!!!! and hey mediator, i know 1.6Ghz is ok but i got a mobo with and old AGP slot with a 32MB graphics card (SIS 300).so i thought of upgrading the essential parts of my system!!!!!!!!!
14-01-2006, 12:30 PM
AMD ATHLON 6400(64 BIT) PROCESSOR
512 MB ZION RAM(400 MHZ)
U GO FOR GIGABYTE MOTHERBOARD ( VIA CHIPSET)
18-01-2006, 04:50 PM
yes vijay is right best config dude
19-01-2006, 10:02 PM
via chipset suck
20-01-2006, 12:16 AM
anyways,
great suggestion, jst the prfct option
20-01-2006, 01:40 PM
what onboard graphcis does it offer ?
26-01-2006, 04:21 PM
hey guys!!! i bought an AMD 3000+ and MSI K8n2 mobo along with 512mb transcend RAM for around 12.5k!!!!!!!!!!!how was the deal???????
26-01-2006, 06:44 PM
SNIST Screamer !!
ifur mobo has onboard Gfx, with an additional PCIE slot,
then its a grt deal
27-01-2006, 10:29 AM
i has a nvidia geforce 6100 gpu on board alongwith one pci-e and one pci-e 16x slot!!!!
Search this Thread |
