Old 12-01-2006, 06:16 PM   #1 (permalink)
Generic Superhero's Avatar
Default Spyware or not?
in spybot i keep on getting two things that u can see in the pic. i think those two r nt spywares. am i right?
in the security center of win xp i chose to monitor firewall and antivirus myself.... is it bcoz of dat?
Generic Superhero is offline
Old 12-01-2006, 06:58 PM   #2 (permalink)
dIgItaL_BrAt's Avatar
i can't even see the pic!
dIgItaL_BrAt is offline
Old 12-01-2006, 07:45 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
well i dont think that they r virus or spyware or adware... i think spybot SnD is worning about some change that u have made on ur system security settings....
did u desabled the windows security center avs & firewall wornings?? check that from the windows security center...
hay!!! r u useing any firewall like ZAP?? if yes then make sure that the Adblocking or stuff like that is turned off!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 12-01-2006, 09:31 PM   #4 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
it's just a security overide
u must have set the windows
antivirus and firewall monitoring to not monitered mode, to avoid popups from the security center
if u delete tht key, u will get security center popup again
vijay_7287 is offline
Old 12-01-2006, 10:04 PM   #5 (permalink)
OOPS!
thanx saurav_cheeta.
