View Poll Results: Which way is better ?
Installing 2.4Ghz cpu which is compatible with existing motherboard 1 25.00%
going for 3.0Ghz cpu along with a new motherboard and 80GB sata harddiskdrive 3 75.00%
Voters: 4. You may not vote on this poll
Old 12-01-2006, 02:07 PM   #1 (permalink)
Default PC SHUTSDOWN AUTOMATICALLY
Hi friends.Myself is Shyam prasad mohanty from Angul,orissa. Ihave following problem with my pc. My pc shutsdown automatically after 1 hour after starting .It emits a scratching sound Just before switching off.The sound seems coming from cpu fan.I have to switch it on again and then this problem continues with decresing timegap. It dont shows any error message.Recently no major hardware or softeare changes is made to the system.I have tried everything to solve this problem including reinstallation of win xp pro along with drivers.
My pc configuration is p4 2.8Ghz,P4i65GV Motherboard from ASRock,40GB harddisk drive from samsung,52x cd RW from samsung,dvd rom drive from sony,2 DDR 128 MB RAM module.
My technisian saying that the cache memory of cpu is corrupted .Is it true? As 2.8 Ghz cpu is not availiable for 478 pin socket here,i have to go for either 2.4 Ghz cpu or 3.0Ghz cpu along with motherboard having LGA775 socket and 80 GB SATA harddisc drive.Please suggest a solution. Thank you.
pupun is offline
Old 12-01-2006, 02:55 PM   #2 (permalink)
check ur motherboard temprature set to 65.c
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 12-01-2006, 03:10 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
wats meant by settin mobo temp
and tht tooo , to 65 degrees
vijay_7287 is offline
Old 12-01-2006, 10:27 PM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Oh if you have a setting to change the temperature, set it to -50 Degree Celcius and overcloak like hell!!! Hehe...
Coming to the point, check the CPU fan for dust, and clean if necessary. Its most probably a heating problem.
kalpik is offline
