Old 11-01-2006, 06:09 PM   #1 (permalink)
Default The C:\ Drive
I just wanted to know if cluttering the C: drive really slows a system down? Can anyone give me a reason...
Secondly...the default "My Documents" location is somethin like
C:\Documents and Settings\<User Name>\My Documents
Is there anyway i can make this point to a location on another drive..say somethin like...
D:\Documents and Settings\<User Name>\My Documents
Zanks!!!!
Forgiveness is the fragrance that a violet sheds on the heel that crushes it. To Forgive calls upon your love, to forget calls upon your strength.
anna_don is offline
Old 11-01-2006, 06:12 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Yes, its better not to clutter your C:\ drive (system drive) Because all your windows files reside on this partition. Also the pagefile is kept on this partition (by default) which keeps on expanding and contracting (again, by default). So if u have un necessary clutter on this drive, the pagefile becomes fragmented, which leads to slowdown...
To change My Documents location, right click My Documents on the desktop, select properties, then on the target tab, you can change the location by using the move button.
kalpik is offline
Old 11-01-2006, 06:23 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
also to clear up ur pc junk clutter, download and use ccleaner freeware utility from www.ccleaner.com.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 11-01-2006, 06:30 PM   #4 (permalink)
thanks...that really helped
anna_don is offline
Old 11-01-2006, 06:30 PM   #5 (permalink)
Yeah...he's dead right! It's always a great idea to change the drive on which the pagefile is assigned! Also, try to keep it as early on the drive as possible so that sys takes lesser time to access this crucial portion of the hard drive!!
AND, defragment the whole Hard drive or not, but DO defragment the C:\ drive REGULARLY!! Same with DiskCheck!
Also, try to Full ScanDisk the Drives!! Not too often but regularly. This'll will it error free!!
I think you would have known the second part... but still I thought i shud tell!!
Ravi.
http://ravishchandra.blogspot.com/
Ravi+ish is offline
Old 13-01-2006, 12:30 AM   #6 (permalink)
to stop pagefile fragmentations and keep enough space for contiguois allocation of newer installed applications' files.
Use Boot time defragmentation on C:\ it makes a great difference
Techie_Geek is offline
Old 13-01-2006, 12:32 AM   #7 (permalink)
dIgItaL_BrAt's Avatar
u can change the default folder locations using TweakUI.
dIgItaL_BrAt is offline
Old 18-01-2006, 04:53 PM   #8 (permalink)
::cyborg::'s Avatar
ALSO USE REG CLEANER BY JOUNI VOURIO 4.3 TO TWEAK UP
::cyborg:: is offline
Old 19-01-2006, 10:18 AM   #9 (permalink)
cyborg, restrain from using CAPITAL LETTERS as it sounds to be in a way RUDE. PLEASE RESTRAIN.
/legolas
legolas is offline
Old 19-01-2006, 11:11 AM   #10 (permalink)
Learner
Kniwor's Avatar
hey friend
http://www.thinkdigit.com/forum/view...=312312#312312
Kniwor is offline
Old 20-01-2006, 02:40 AM   #11 (permalink)
TechGuru#1's Avatar
As in similar view 2 keep the C drive practically empty at BESt,i have kept the size of C drive at 10Gb.
Now IS THIS SUFICIENT for the page files,temp files,program files,system files,dll's etc.
I dont want 2 install anything/any apps etc on this C drive!
So is my approach CORRECT?
TechGuru#1 is offline
Old 20-01-2006, 04:31 AM   #12 (permalink)
Learner
Kniwor's Avatar
i make c:\ 10 Gb too, just because i dont mind 10Gb on my 250Gb HDD.
though i install all common apps in c:\
so u are fine as long as u dont install anything like Far Cry, Doom3, or San Andreas on ur c:\ drive...... i hope u get the point...
inspite of all this i always change my temporary variable in other drives to avoid problems
Kniwor is offline
Old 20-01-2006, 06:20 AM   #13 (permalink)
TechGuru#1's Avatar
So,THAT's the WAY!
Old 20-01-2006, 05:45 PM   #14 (permalink)
Learner
Kniwor's Avatar
So,THAT's the WAY!
yeah, i never face any space problems,
to be more specific, u might want to change the temporary folder of nero vision, because sometimes u might want to encode large video files and c:\ might not be enough.
i also change the temporary folder of Internet Download Manager because i do large downloads at times.
most ofted the c:\ drive is eaten up by these temporary folders
Kniwor is offline
