if u know the file name try searching that filename(using windows search engine) in ur c drive(cuz most probably the file would be saved on ur c drive)....... if that doesn't help......... try searching for all files having extensions .avi,.mpeg,.mpg,.3gp etc. etc............ try all the extensions(for video files) u know and see if that helps........... out of the results u can either try and look for a file with a name similar to the name of the video u saw............ or otherwise u can try and play each file( which would consume a lot of time)............ once u get the file u were looking for just see its path(using the properties) and next time onwards look for the files in that particular location........ hope it would solve ur problem
