Old 11-01-2006, 11:50 AM   #1 (permalink)
::cyborg::'s Avatar
Default DVD TO VCD
Can any one plz tell me how to convert dvd to dat(mpeg) file so that it can be read by those players who dont have dvd support without any quality loss :roll: :roll: :roll: :roll: :roll: help!! ts urgent!!
thanks in advance
::cyborg:: is offline
Old 11-01-2006, 11:54 AM   #2 (permalink)
just use DVD ripper tool that is s/w of size 3.88 mb
patelviren is offline
Old 11-01-2006, 12:25 PM   #3 (permalink)
hansraj's Avatar
have a heart dear ... how can it be possible that u convert a dvd to a vcd and there is no quality loss... its just that how much compromise can u make.... i tried this once and found dvdx very nice as u can keep changing the settings for various quality and it will take more or less time depending on the setting for the conversion.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 11-01-2006, 05:57 PM   #4 (permalink)
But to play them in VCD player, no other way than converting to VCD which means less quality with Nero or Ulead DVD Movie Factory 4. The second one may give you better VCD quality if you alter the settengs to high quality. That is the maximum possible.
Yesterday - Dead
Today - Dying
Tomorrow - Never dies
The day after tomorrow - Where will you be !
Sreekanth V is offline
