Old 11-01-2006, 11:48 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Net Speed ! ! !
how do u check ur Net Speed (in kbps) ??? any freeware software bt light on system ...
ax3 is offline
Old 11-01-2006, 11:51 AM   #2 (permalink)
I think DUMeter might help you.
http://www.dumeter.com/
http://njaan.blogspot.com/ - A Malayalam Blog
pratheesh_prakash is offline
Old 11-01-2006, 02:57 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
u can also check it online at
www.zdnetindia.com
and also with bandwidth tester extension in firefox
vijay_7287 is offline
Old 11-01-2006, 06:09 PM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
http://www.speakeasy.net/speedtest
IMHO the best one and most accurate...
kalpik is offline
Old 13-01-2006, 04:29 PM   #5 (permalink)
ax3
ax3's Avatar
have downloaded bandwidth meter extension for FFox ... bt how 2 use it ???
... W H O T ...
ax3 is offline
Old 13-01-2006, 05:25 PM   #6 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
just by clickin on it
it will available under the tools menu
and by the way it is not compatible with firefox 1.5
Old 13-01-2006, 05:36 PM   #7 (permalink)
bala4digit's Avatar
even www.2wire.com
speed tester is there in top !!!
\"I\'ve Got A Great Ambition To Die Of Exhaustion Rather Than Boredom.\"
\"Where Would You Go When You Can\'t Forget The Past And You Don\'t Know The Future.\"
bala4digit is offline
Old 13-01-2006, 05:39 PM   #8 (permalink)
bala4digit's Avatar
hey kalpik...the link u gave ...says my speed is 91kbps for d/l n 71 for upld...but my connection is just 64kbps...is that acurate
