Originally Posted by iinfi
By switching off the PC i meant shutting down the PC and switching the CPU power switch form the back of the CPU.
The ethernet cable will still carry a potential difference with which it could give power to the HDD and access it.
But i dunno if thats possible.
regards
arvind
Back of the CPU means?? are you switched off that black switch located in SMPS, just next to SMPS fan ? In that case its not possible to power on the
pc remotely! For WOL its requires a stand by +5V power to make the pc
on. But if you off that black switch then Stand-by power goes off. So its not
possible. But if you just shutdown the pc and windows / linux off the CPU power then its possible to power it again by sending magic packet through
LAN card.
