Old 10-01-2006, 12:25 PM   #1 (permalink)
nach p's Avatar
Default harddisk not detected
Hello guys.
Few days ago when I turned on my pc(after 2-3 hours),the hard disk was not detected. I tried it elswhere but I encountered same problem.I also changed my IDE connectors but also of no use.
My hard disk was samsung 40gb SV0412H (3600RPM)
I have an P3 1000MHZ &ASUS MOTHERBOARD.
What can be the problem ?
How can I recover my data?
Is it of no use now?
nach p is offline
Old 10-01-2006, 12:44 PM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
i think u got a hard drive failure. do not try to repair it yourself
go to the samsung service center
try them to remove the bug
gary4gar is offline
Old 10-01-2006, 04:42 PM   #3 (permalink)
yrana2002's Avatar
God bless you if you have the hard disk under warranty. If not, then bless the manufacturers for buying a new hard disk.
You can open your cabinet & disconnect the power or data cables, reconnecting them again. This can solve a problem many times. Check your BIOS to see if your PC really discovers your hard disk or not.
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 10-01-2006, 10:34 PM   #4 (permalink)
nach p's Avatar
Yeah I had seen in BIOS when it had not detected.checked all settings but of no use,soI think it is now not a case in my hand.
thank u guys for reply.
nach p is offline
Old 10-01-2006, 11:10 PM   #5 (permalink)
Learner
Kniwor's Avatar
ur ecb is gone as it seems so u can get ur data back if thereś anything imp. but uĺl need a new HDD anyway
Kniwor is offline
Old 12-01-2006, 01:12 PM   #6 (permalink)
nach p's Avatar
Thank u guys for reply.
I had take n new 80 gb puma Samsung Hard Disk.
nach p is offline
Old 18-01-2006, 05:04 PM   #7 (permalink)
::cyborg::'s Avatar
INSTALL HDD LIFE AND ENABLE SMART FROM BIOS THIS WILL GIVE U A WARNING MESSAGE MUCH BEFORE UR HDD FAILS
::cyborg:: is offline
Old 19-01-2006, 03:30 AM   #8 (permalink)
Default mr nach p
hi,
nach p
plz check backside of ur hdd all pins are ok or not
next change the signal cable, change ur hdd 2 master if it is in slave
change 2 slave if its in master check the jumper settings
try in others systems
all the best
regards
jnreddy
jnreddy is offline
Old 19-01-2006, 01:29 PM   #9 (permalink)
nach p's Avatar
Hey guys, My all HDD pins are ok. Changed signal cable ,IDE connectors , changed jumper settings from master to slave ,from primary to secondary but of no use.What should I do with this dump Hard Disk ?
As Cyborg told I had installed HDD LIFE software on my new Hard Disk & is working fine.
Thank you again for replies.
nach p is offline
Old 21-01-2006, 09:33 PM   #10 (permalink)
hi,
nach
i more suggestion is 2 plz try ur hdd in other systems
if the problem persists then ur hdd may be culprit
regards
jnreddy
jnreddy is offline
Old 21-01-2006, 11:49 PM   #11 (permalink)
__Virus__'s Avatar
Get a box, fill it with 1 KB TNT and detonate
__Virus__ is offline
Old 22-01-2006, 10:44 PM   #12 (permalink)
::cyborg::'s Avatar
i think u open it and see its interiors and try to understand (new adventure)
