Old 22-10-2004, 04:48 PM   #1 (permalink)
Ethan_Hunt's Avatar
Default Folder Locking
Hey guys i need a software that would lock or protect the folders i want to by a password.For suppose if i want to lock a games directory then it should be such that the game icons on the desktop should work perfectly i.e the game should work even though the root folder is locked.plzz help me out.
Ethan_Hunt is offline
Old 22-10-2004, 05:19 PM   #2 (permalink)
u shd try out Folder Lock, it works pretty well i think. or if u r using WinXP, try using NTFS...it has some of those capabilities, though i m not really sure about that.
cg84 is offline
Old 22-10-2004, 05:48 PM   #3 (permalink)
i am usin WinXP Pro and i hav one partition NTFS but i cant lock the folders...
...walking thru the twilight zone...there was no beginning...there is no...end...
www.baikunth.doornumber3.in
www.thefutureforest.com
FunkyB is offline
Old 22-10-2004, 05:57 PM   #4 (permalink)
Magic Folder works for me. Use Encrypted Magic Folders . Go Here For More Info
Walk on the Wild Side. The other side SUX!!!
krazydude is offline
Old 22-10-2004, 06:37 PM   #5 (permalink)
The Photoshop Guy
cooljeba's Avatar
here is a nice trip that works on 98 me
it doesen't work on XP
go to dos prompt
and create a new directory:
md hello
then rename it as
ren hello alt+255
*note hold alt and u type 255
and press enter
that's all ur folder is locked
to open it do the reverse
njoy!!!
..:: peace ::..
Jeba
cooljeba is offline
Old 22-10-2004, 06:54 PM   #6 (permalink)
Default Heres the answer
i have written off the answer a few weeks ago.....u can do it without any software at all...
u can check it Here
__...:::---*Keyboard Cowboy*---:::...__
whistler is offline
Old 22-10-2004, 11:19 PM   #7 (permalink)
NikhilVerma's Avatar
Just Google for "Hide Folders XP download" there is a software with the same name. I use it and it's nice....
NikhilVerma is offline
Old 23-10-2004, 12:45 AM   #8 (permalink)
sms_solver's Avatar
If you don't find good sw then i have a suggestion
make a folder in %windowsfolder%system
and follow cooljeba's trick
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 23-10-2004, 01:02 AM   #9 (permalink)
Ashis's Avatar
Hey,
If UR Using XP On NTFS; Then Turn Off simple file Sharing (Tools>Folder Option>View>Use Simple File Sharing (Recomended) (Turn it Off)) Then Reboot.
Now U will find a Security tab in folder's Property Dialog Box (Similar to windows 2000).
Use it to set permission.
I hope it would Help U......
Ashis is offline
Old 23-10-2004, 11:18 AM   #10 (permalink)
Bewitched!
xenkatesh's Avatar
There r various sowtware which allows my choice is MAGIC FOLDER available at
http://www.pc-magic.com/des.htm#mf
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
