Old 22-10-2004, 04:15 PM   #1 (permalink)
Default Computer restarts frequently?
Hello Sir,
I am Sandeep Sharma a website designer working in Jaipur, I recently purchased an Intel 2.4 GHZ P4 HT with Intel Desktop Board D865GBF .From past 5 days I am facing a strange problem. My system display is not working properly. Whenever I start playing games like Serious Sam the game runs 4 to 5 minutes perfectly and then the computer restarts automatically but this problem is not face by me in any other computer. Is it a hardware problem or a software problem? Please help me.
Thank you
Sandeep Sharma
Sandeep Sharma is offline
Old 22-10-2004, 07:30 PM   #2 (permalink)
Hi,
Make sure you are using the latest version of Direct X drivers required by your game. Also, you havent mentioned if you face the same problem when running other apps??
sailendra is offline
Old 22-10-2004, 08:23 PM   #3 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
get ur GFX drivers updated from its web site... Direct X 9 c...
which os? (if XP then upgd 2 XP SP2)
checked for virus/spyware?
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 26-10-2004, 03:33 PM   #4 (permalink)
Default Re: Computer restarts frequently?
I think the problem with the display card.... Pls uninstall the display card driver and install it again. Or change the RAM and try it....
Originally Posted by Sandeep Sharma
Hello Sir,
Thank you
Sandeep Sharma
Kamaleshwaran is offline
