Old 08-01-2006, 12:50 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Flickering ! ! !
I have a XP machine ... also watch vcd`s on my machine ... bt while watching movies through my cdrom drive (DMA is also enabled), my hdd light also flikkers ...
why is that so ???
ax3 is offline
Old 08-01-2006, 08:19 PM   #2 (permalink)
asia://india/ka/bangalore
a_to_z123's Avatar
That's because the data is first read from the CD-ROM and put into buffer temporarily which is on the HDD.
Hence the HDD light also flickers when data is read even from the CD-ROM.
:) I've got my F, C and K . Now all I need is You !!! :)
a_to_z123 is offline
Old 08-01-2006, 09:08 PM   #3 (permalink)
Also to watch movies you must be using Windows media player or any other media player.
And dude these programs are installed on your hdd.
So if the hdd shows activity then it is absolutely
normal.
So dont bother about the led and simply enjoy your movies.
amitsaudy is offline
Old 10-01-2006, 04:19 PM   #4 (permalink)
::cyborg::'s Avatar
bcoz program is used which is on ur hdd
::cyborg:: is offline
