Old 08-01-2006, 07:44 AM   #1 (permalink)
Default What does this mean and How to start the computer , HELP !
MY other system has started giving me this message , ' Unmountable Boot Volume ' etc.... and refuses to start , Is there a way to start the system ? I just hope all my Data on the hard disk is safe , Why did it happen ? What should I do ?
Huzefa is offline
Old 08-01-2006, 09:49 AM   #2 (permalink)
yrana2002's Avatar
Most probably, following are the causes:
1.The file system is damaged and cannot be mounted.
2.You use a standard 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
3.The basic input/output system (BIOS) settings are configured to force the faster UDMA modes.
First, try this:
Go to your Bios and restore your default settings.
If it's a damaged file system case then:-
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This should solve your problem.
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 08-01-2006, 05:32 PM   #3 (permalink)
thnx for your quick reply , yrana , but its not working, any other things I can do ? My data on the HD is safe I can access it on my friends computer , Is there another way besides formatting and re-installing winxp ???
Huzefa is offline
Old 08-01-2006, 06:20 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
hope these links help u
http://www.windowsreinstall.com/inst...nmountable.htm
http://www.techtips4u.com/kb/sw/SW00014.htm
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
