Old 21-10-2004, 10:38 PM   #1 (permalink)
Default Tally - Help Installing
this is the error i get when i try to install Tally
im using WIN XP SP2
i was using Norton AV 2003 pro earlier
now using Kaspersky Personal
plz reply asap
thnx
talrejaharish is offline
Old 21-10-2004, 10:39 PM   #2 (permalink)
sorry ... took the wrong link by mistake
this is the actuall error
plz check this
Old 21-10-2004, 11:57 PM   #3 (permalink)
Laptoping
Sourabh's Avatar
Default wht version??
whts the version of tally u using
btw TALLY 5.4 is not compatible with winxp
it runs in educational mode
theres no link between TALLY n AV
and if u use tally 6.3 then it shld work in XP
also is ur copy of tally legal??
i have a legal Multi user edition of tally 5.4 brot for 18 k four years back
n mine doesnt work in winxp
have contacted them a lotta time b4 but they say it has compatibility issue
FINALLY TEMME UR VERSION I'LL TELL U WHT TO DO U NEED TO INSTALL IT AGAIN N CHANGE THE TALLY INI FILE LOCATION URL
Sourabh is offline
Old 22-10-2004, 07:05 AM   #4 (permalink)
The Photoshop Guy
cooljeba's Avatar
tell the version u using m8
..:: peace ::..
Jeba
cooljeba is offline
Old 22-10-2004, 07:29 AM   #5 (permalink)
what version of tally u r using talrejaharish.....?
imgame is offline
Old 22-10-2004, 10:54 AM   #6 (permalink)
havent installed it ever before
tats wat it is on my frenz Win 98 SE
coz he said it doesnt work on his XP either
tally 6.3.1
any solutions for the same ??? as i hav only Win XP
Old 22-10-2004, 10:13 PM   #7 (permalink)
tuxfan's Avatar
Contact Tally Help. If it is a pirated version, I would strongly recommend buying a authenticated version. Don't risk losing your accounts. They are far too valuable.
Just FYI, one of my clients used a pirated Tally version. He was supposed to have his accounts audited and file Income Tax returns before 31st Oct. or pay a penalty of Rs. 100,000/-. Now his data files are all corrupt and hardly anytime is left. He may have to sit and re-enter full data in no time and also get them audited or run a hugh penalty risk. All this to save a sum of Rs. 10,000/- In March Tally 6.3 was available for Rs. 5,000/-!!
tuxfan is offline
Old 22-10-2004, 11:44 PM   #8 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Nope Harish ... Norton Antivirus is causing the problem again .. It isnt uninstalled properly ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 23-10-2004, 01:03 AM   #9 (permalink)
So wat do i do to uninstall norton properly ???
downloaded som fix from Nortons site for Rnav removal
it supposedly removed all data ... but its not good enough as all the shared files r still there
Old 23-10-2004, 07:24 AM   #10 (permalink)
The Photoshop Guy
cooljeba's Avatar
try cleaning your registry with regcleaner and if u have norotrn utilities try fix windows problems that will cleap up a lotta left over files.
..:: peace ::..
Jeba
cooljeba is offline
Old 23-10-2004, 11:10 AM   #11 (permalink)
Bewitched!
xenkatesh's Avatar
upgrade to the newer version. first clean ur pc registry with AD-AWARE .then install!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 23-10-2004, 11:46 AM   #12 (permalink)
tuxfan's Avatar
Check out these links for removing Norton AntiVirus 2004 after Add/Remove fails. I think the steps would be similar for NAV 2003 Pro.
Win XP
Win 98/ME
Be careful, it tells you to edit registry entires.
tuxfan is offline
Old 23-10-2004, 08:58 PM   #13 (permalink)
i tried the link
Win XP
tried Registry Mechanic and one more registry CLeaner (forgot the name)
but cant solve the problem yet !!!
and now im unable to install Adobe Premiere 6 also
hey {batty} i think last time u made some registry for me which solved the problem ... can u do sumthin again !!! [/b]
Old 24-10-2004, 01:12 AM   #14 (permalink)
hey one more thing ...
i had installed Norton Utilities 2003 n somehow it was not uninstallin
n now the folder n program files is also not there
n when i try to reintsall from the same cd
it says ...
a similar version is runnin on ur system
But in add remove i cant uninstall it
can anyone help now ???
Old 24-10-2004, 05:24 PM   #15 (permalink)
tuxfan's Avatar
Check out the links that I have given you. It gives steps to completely uninstall NAV even when Add/Remove fails. That will help you to remove all traces of it from your machine.
Secondly, download TweakUI (for Win98) or PowerToys (for WinXP). It will let you repair your Add/Remove list. May be after that you will be able to uninstall it.
tuxfan is offline
Old 25-10-2004, 10:43 PM   #16 (permalink)
well well well i m running tally 5.4 from my win xp ...it is possible to run and work on tally 5.4 in win xp and havent found any problem yet?why did u guys have ti don't know but it does work in xP
Life is a game.....Play it to win.
visvo is offline
Old 26-10-2004, 11:27 AM   #17 (permalink)
tuxfan's Avatar
Tally 5.4 may work because it is a windows based version. Tally 4.5 will not work because its a DOS based version
tuxfan is offline
Old 28-10-2004, 11:35 AM   #18 (permalink)
Hey
my problem solved !!!
I got a solution from Microsoft Knowledge Database but i cudnt understand it !! needed editing of registry.
Batty helped me and edited my registry to remove the specified Virtual Device Driver !!!
from the registry ...
rebooted and it works now
as for Tally installation
i got a zipped file from my frend ... wich on double clickin extracts itself to Crogram Files ....
and then u can get the shortcut on ur desktop and run Tally 5.4 from there on Win XP
so no need to install it .. jus copy paste the folder and it works
and Batty thnx a lot for Solving the problem
and evryone else :
tuxfan
visvo
xenkatesh
cooljeba
imgame
Sourabh
for trying to help me out
now i don need to format my drive and reinstall windows
so that post also is a waste now
so now my Adobe Preimere 6.0 and Tally 5.4 both work fine on Windows XP !!
Old 28-10-2004, 12:45 PM   #19 (permalink)
tuxfan's Avatar
Glad to know things are working to your satisfaction now. But don't offer to give Tally 5.4 to others. You are violating forum rules :roll:
Anyway, I am a legal Tally user
tuxfan is offline
Old 28-10-2004, 03:03 PM   #20 (permalink)
sorry tuxfan and digit ...
dint know bout tat ...
Old 29-10-2004, 11:10 AM   #21 (permalink)
tuxfan's Avatar
sorry tuxfan
Uhh? Why a sorry to me? Anyway ...
and digit
That could save you from a warning
tuxfan is offline
Old 13-11-2004, 06:31 PM   #22 (permalink)
Default hie
hi
i wanted soem help abt tally
i m using xp as o/s
and i installed tally ees6.3 but it ask for activation key
can anyone help me
ashishkamat is offline
Old 14-11-2004, 12:41 AM   #23 (permalink)
No sir .. Get yourself a licensed version ...
Old 16-11-2004, 12:17 PM   #24 (permalink)
tuxfan's Avatar
True. Get yourself a licensed version. Its now available for only about Rs. 7500. And you can use it for so many years and in case of trouble get help from their support staff too. Its worth it.
tuxfan is offline
