Old 07-01-2006, 10:01 PM   #1 (permalink)
doom_marine's Avatar
Default THX And dolby
I wqas watching my DVD on my home theatre and saw how the THX and Dolby Ads in the starting showed the effect of surround sound.
Is there anyway i can make a copy of this trailor in my computer so i can check it out on my 5.1 speakers connected to my system
AMD Athlon X2 4200+
2GB DDR 400 RAM
nVIDIA 7800GTX 512MB x 2 SLI
Creative X-Fi Fatal1ty Sound Card
400+160+74GB HDD SPACE
doom_marine is offline
Old 07-01-2006, 10:18 PM   #2 (permalink)
asia://india/ka/bangalore
a_to_z123's Avatar
Yeah, if you have a DVD-ROM then you can.
If you have Nero Recode then you can re-encode the file with Dolby Digital 5.1 sound and then play it on your PC.
And if you want then just copy the corresponding .vob file and play it directly.
Moreover I think that 5.1 channel soundcards have an in-built utility with their driver to check whether all the speakers are working or not!
:) I've got my F, C and K . Now all I need is You !!! :)
a_to_z123 is offline
Old 09-01-2006, 02:14 AM   #3 (permalink)
TechGuru#1's Avatar
Give a LINK to ONLY the THX & DOLBY Ads.........
ANYONE with tha link?
TechGuru#1 is offline
Old 09-01-2006, 05:19 AM   #4 (permalink)
alrite, here you go: http://www.cinenow.com/us/vobtrailer.php3
A simple Google search wouldn't have hurt you but never mind. Let's just say that you got lucky coz i also wanted to check out the trailers on my speakers.
geekysage is offline
