Old 21-10-2004, 08:18 PM   #1 (permalink)
cool_dude_prav's Avatar
Default Help me pleaaaase......!
My system keeps switching off suddenly without any warning. My system is Pentium 4 2.4 Ghz, 256MB DDR-RAM, 17" SAMSUNG monitor.
The Bloglines of an Angry Indian -
www.angry-indian.com
If only life were as easy as Ctrl+Z (undo) and F4/Ctrl+Y (redo)...
cool_dude_prav is offline
Old 21-10-2004, 08:29 PM   #2 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
does it gives any warning like RPC... will shut down in 59.. 58... 57 secs..?
what's specs of ur system... OS???
describe ur problem in bit detail...
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 22-10-2004, 12:04 AM   #3 (permalink)
ya give your full details
but if your system just restarts after some time then it might be due to intel application accelertor -it caused similar problems in my system, uninsatlling it will solve the problem
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
technoteen is offline
Old 22-10-2004, 12:44 AM   #4 (permalink)
Yes pls give atleast details of ur system.
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 22-10-2004, 05:38 AM   #5 (permalink)
sidewinder's Avatar
Check ur mobo and athe smps.But before that at least give us some details.....
sidewinder is offline
Old 22-10-2004, 11:31 AM   #6 (permalink)
i think u have got a faulty smps plz change it and see your problem is solved if not then plz do give us full detail waise i think ur problem is of smps only.
Life is a game.....Play it to win.
visvo is offline
Old 22-10-2004, 01:29 PM   #7 (permalink)
used to happen 2 my system i dont know why even though the smps was fine. so i formatted n reinstalled my os as it was loaded with spyware n all also, and after that i dint have any probs.
ishaan is offline
Old 22-10-2004, 01:51 PM   #8 (permalink)
Default From the Junk
U guys out there. Do u know how to change the floppy name when inserted disk into floppy drive. Like when the CD drive name changes to the CD name.
tur'bog'eek is offline
Old 22-10-2004, 01:55 PM   #9 (permalink)
Default Re: Help me pleaaaase......!
Hey.! If you are running Windows Xp then your system is infected with Sasser worm ...
I suggest yout ovisit http://support.microsoft.com and
http://www.symantec.com for more details.
Old 22-10-2004, 05:12 PM   #10 (permalink)
Hanging, since 2004..
tarey_g's Avatar
RAM is loose on grip with the mobo slot or not installed properly. so attach it more firmly
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is offline
Old 22-10-2004, 05:15 PM   #11 (permalink)
if RAM was loosely gripped or not installed properly, imho the system would not have started in the first place. i believe the SMPS is the culprit here...u shd get that checked first.
cg84 is offline
Old 22-10-2004, 09:47 PM   #12 (permalink)
yaa... if ram is the problem then u never able to start ur pc coz it starts biping as soon as u press the power button.. so plz meri baat maan lo apna SMPS change karo
visvo is offline
Old 22-10-2004, 09:51 PM   #13 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
U probably hv a faulty SMPS. Get it checked by a technician. Also, if ur PC is attached to a UPS, try running ur comp without th UPS, and get th UPS checked too. It cud be that u hv a weak power supply.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 23-10-2004, 11:42 AM   #14 (permalink)
Bewitched!
xenkatesh's Avatar
Check Ur Smps dude!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 23-10-2004, 05:27 PM   #15 (permalink)
maybe u hav ram in both slots and the primary one is fine so the system boots up....but the secondary one is loose
ishaan is offline
Old 24-10-2004, 06:14 AM   #16 (permalink)
STOP ! its all bout SMPS i checked it my self and found that its the faulty SMPS thatz causing mess with that chaps pc ..so plz discontinues this topic and head for a new one what u say admins?
visvo is offline
Old 08-11-2004, 12:37 AM   #17 (permalink)
Ashis's Avatar
If Ur System Is new; Contact Ur Dealer (There Mey be 100s Reason for Ur Problem)
Ashis is offline
Old 09-11-2004, 01:07 AM   #18 (permalink)
swatkat's Avatar
There may be many reasons,You have to give more info about ur system.Probable reasons are:-
1]Faulty SMPS
2]Faulty CPU Fan (Over heating problem)
3]Blaster Virus(if u rum Win XP and u get some RPC message when u r connected to net)
4]loosened RAM (System does not boot at all).
http://swatrant.blogspot.com/
swatkat is offline
