Old 21-10-2004, 04:17 PM   #1 (permalink)
ArZuNeOs's Avatar
Default Help out Plz Waaa Waaa Waaaaaaaaa.I Get Mad-WNASPI32 ,800Mb
whenever i play in Real audio or try using hero video i get a message
"The application or DLL D:\WINDOWS\System32\WNASPI32.DLL is not a valid image.Please check this against your installation diskette.
I use Win98 on C:
Win Xp Pro on D:
I also use Samsung Cd rw SW224B
Samsung Cd Rw\Dvd SM352B
Does These support 800 mb cds
How do I Use Them
I use Ahead Nero that came bundled Ver 5.5.10.35
Sorry For The Trouble
I am new
I am In ahurry
Plz Hlp Me
ArZuNeOs is offline
Old 21-10-2004, 04:23 PM   #2 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Probably ur ASPI drivers r corrupted. Under which OS does this error come up?
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 21-10-2004, 06:21 PM   #3 (permalink)
You need to download the latest ASPI drivers from <<here>>
To use 800 MB cds, you must first enable the Overburning option in Nero.
Please check out this link:
http://www.nero.com/en/FAQs_Data_CD.html#5
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
Old 22-10-2004, 02:57 PM   #4 (permalink)
ArZuNeOs's Avatar
Sorry I forgot
The Problem Is in Both the Os I downloaded The latest drivers but confused at where to install . How to check My cd Writers support Overburning?
Plzzzzzzzzzzz
Back to the world of realms
ArZuNeOs is offline
Old 22-10-2004, 09:33 PM   #5 (permalink)
i think u should try reinstalling the software... this might fix ur prob
Life is a game.....Play it to win.
visvo is offline
