I have a 1.8 Ghz ,512MB Ram, winxp prof. PC with a Mercury TV Tuner card.How can I record with maximum resolution?When I watch TV on PC the resolution is good,but when I try to record in higher resolution the video becomes blurred.Please help.
If you want better resolution for capturing use
1) Processor higher than 2.0 GHZ, 512 MB or more RAM
2) Use Pinnacle's video capture card
You capture in MPEG-2 (ie., DVD quality video)
3) Use the right software like Pinnacle Studio for
capturing & burning
4) You can burn directly to DVD!!
All this is possible if you are willing to spend 10, 000
to 15, 000 more!!
