Old 05-01-2006, 10:37 PM   #1 (permalink)
Default Knowledge share regarding MAC addresses
Dear friends,
Did u know that mac addreses of many PC's can be changed
Visit:
http://www.nthelp.com/NT6/change_mac_w2k.htm
But remember Not all LAN's hav the Mac address property.
LANCER and Tech com were the companies who provided this property earlier
This property is no longer Available with the LAN's Of Today.
Andyiz is offline
Old 06-01-2006, 04:24 AM   #2 (permalink)
invisible
Posts: n/a
U can change MAC address of you LAN card with many softwares.If u search the forum u will get it.
Man what do u mean by this ' This property is no longer Available with the LAN's Of Today'.?
every LAN card has MAC address property.and u can change it.if u want the softwares i will give the links.This is call MAC spoofing.
Old 06-01-2006, 02:44 PM   #3 (permalink)
u can simply change it from hardware properties under device manager ..
not a big deal
No Mercy, No Limits.
theraven is offline
Old 06-01-2006, 03:21 PM   #4 (permalink)
invisible
Posts: n/a
not a big deal
ye
Old 06-01-2006, 04:05 PM   #5 (permalink)
Default Reply
U got it all wrong Mr invisible, Not every Lan has that Property (mac address Property) but has a unique 48 bit mac address assigned to it which can be changed easily changed using Network or mac address property.
Hope u got it
Proof:
Check out whether u can change the mac adress of Pc's in our Coll\ office, i bet will surely find one Pc atleast which wont hav that property
Generally Motherboard having INBUILT LAN wont hav that property.
And BTW with "This property is no longer Available with the LAN's Of Today" is meant that lans manufactured nowadays(recently) wont hav that property for security reasons
i never meant that Mac address cant be changed if that property is absent
using Smac everthing can be done
i emphazied on how easy it is to change tha mac if the Lan itself has that property, no need to use snooping soft(Smac).
if its isnt available(property of mac address), then smac is handy but risky.
Got it ????????/
Andyiz is offline
Old 06-01-2006, 05:32 PM   #6 (permalink)
invisible
Posts: n/a
Default Re: Reply
Hope u got it
Proof:
Got it ????????/
can someone understand what this guy is saying?
Old 06-01-2006, 07:30 PM   #7 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
I think he means.. that earlier we could change the MAC address via device manager only... but now we cannot. But thats not true...
kalpik is offline
Old 06-01-2006, 08:41 PM   #8 (permalink)
Default reply
What is with u all, guys? Y cant u understand such simple things
Let me make it simpler
u can change ur mac address Via Device Manager(i dont deny it)
Rite
Now consider the case wherein ur Lan card is damaged, and u are forced to buy a new one.
Now with the New one u cant change Mac Via Device manager
bcoz u wont find that property of MAc or Network Address
Remember, whether u can change the MAC or not , depends on the LAN and Not the OS.
Dont be under the impression that one can Change the MAC Address of all the PC's Via Device Manager.
U all Can bcoz ur Lan Card Supports that property
Try Changing the Lan Card or Else Try It With Some other PC's
I could change my MAC Before but not any longer After i bought the New Lan.
Andyiz is offline
Old 06-01-2006, 10:07 PM   #9 (permalink)
kalpik's Avatar
Thats not true... It solely depends on the LAN card manufacturer, and the driver, not on new/old cards... I bout a card a week back, and i can change the MAC address via device manager.
Anyway, why such a fuss on changing MAC address via device manager?? Everyone knows there are tons of utilities to change MAC address!
kalpik is offline
Old 07-01-2006, 03:34 AM   #10 (permalink)
invisible
Posts: n/a
Default Re: reply
Rite
its all wrong
u shud b able to change now also.DOnt use device manager.Use any free utilities in softpedia.com
there are lots of apps...for MAC spoofing
Old 07-01-2006, 07:05 AM   #11 (permalink)
siriusb's Avatar
Ok, the confusion seems to be not knowing what mac spoofing is. The mac address stored on a rom in your lan card is not changeable. When you are mac spoofing, only the OS's view of the address is changed. It absolutely does not depend on the manufacturer/date of manufacture or onboard/external lan card. As long as the OS allows it, it can be done. Even if it doesn't you can probably reshack it, I guess.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 07-01-2006, 10:20 AM   #12 (permalink)
Default Re: reply
Rite
its all wrong
I am aware of the Soft that enables us to change the MAC address.
But i cant Via Device Manager( Which i used previously) to change Mac address.
Hope its clear
Andyiz is offline
Old 07-01-2006, 10:26 AM   #13 (permalink)
To change the MAC Address Go To
My Computers->Properties->Hardware->DeviceManager->NetworkAdapters
Right Click on your LAN card.Then Go To
Properties->Advanced->LocallyAdministeredAddress
Check the option of your value and enter a 12 digit Hex Code
Sometimes some companies have some rule about the starting letters of the address so the best option is to change the last few digits of your actual MAC address
rachitar is offline
Old 07-01-2006, 10:22 PM   #14 (permalink)
Default reply
Y dont u read the forum properly
The discussion here is not how tho change Mac address, but the discussio is about some Lan card which wont have the network adress property
so one cant change the Mac adress in the Way u mentioned obove
In these Lan's u wont Find any thing called as " LocallyAdministeredAddress Or network add or Mac adress( depends on manufacture)" . so One cant change the maC ADDRESS
Though using Softwares it can stil be done even if the Foresaid property is absent.
Once again Requesting u to read the posts Carefully and then Answer
Andyiz is offline
Old 08-01-2006, 02:14 AM   #15 (permalink)
invisible
Posts: n/a
Default Re: reply
I think you are doing it wrong.
hey just change networkaddress in devicemanager.thats it.
and btw every lan card will have this property.
Old 08-01-2006, 10:23 AM   #16 (permalink)
Default Re: reply
Both the Methods Gets u to the same area
Both are valid
both an be used to change the Mac
Mr Invisible y dont u try changing the mac adress of the pc's in our Office or @ Home and then Come back to me
Can nybody make this Guy understand???
Mod PLz help
Andyiz is offline
Old 08-01-2006, 11:07 AM   #17 (permalink)
Chill, guys.
I think what Andyiz is trying to say is that his comp's NIC (network interface card; calling it *LAN card* is too crude IMHO) doesn't have the property to change the MAC address via the windows device manager i.e. does not allow MAC spoofing via the device manager.
Although I have personally not found any card which doesn't allow the change, some chipset manufacturer(s) might have disabled the property. AFAIK and as evident from previous posts, we can always use 3rd party apps to spoof the MAC.
Hope invisible will get andyiz point now. Andyiz, i know it's frustating when people don't understand what you are trying to say but the key is to remain calm and try to be as clear as possible.
Peace.
geekysage is offline
Old 08-01-2006, 03:08 PM   #18 (permalink)
invisible
Posts: n/a
update the LAN card drivers.
Old 09-01-2006, 12:22 AM   #19 (permalink)
does ur head have ANY connection to ur hands when u type rot ?
theraven is offline
Old 09-01-2006, 12:36 AM   #20 (permalink)
I wanted to say that so badly but didn't wanna hurt anybody.
Old 09-01-2006, 12:52 AM   #21 (permalink)
siriusb's Avatar
Actually, some cards don't allow changing their mac address in eeprom. Such cards disallow it by not providing the device driver support for changing it. Updating the lan driver in that case is a long, but, logical shot.
siriusb is offline
Old 09-01-2006, 02:03 PM   #22 (permalink)
Default reply
Originally Posted by geekysage
Chill, guys.
Peace.
I had tried to convey wat u did successfuly
It took 4-5 posts to make Invisible And others understand
I think even Mahatma gandhi Would have Lost his cool
I must admit i got frustated,
this will Never be repeated
anyways tnx for conveying wat i eventually want to convey
Andyiz is offline
Old 09-01-2006, 02:12 PM   #23 (permalink)
Default reply
LOL
Andyiz is offline
Old 09-01-2006, 02:14 PM   #24 (permalink)
Default reply
Not recomemded( updating)
Andyiz is offline
Old 09-01-2006, 02:17 PM   #25 (permalink)
@sirius if the manufacture is disabling change of mac add. thru device drivers then its quite obvious that if they update there drivers they'll still be blocking it
besides the fact that for a thing like NIC's, the drivers are rarely ( or never ) updated.
at most say ur using drivers for another lan card , which again i might add doesnt work since ive tried using generic drivers for lan cards ..
just doesnt get detected.
unless there are hacked drivers ... but then again liek i said .. for somethign like NIC's no one goes thru soo much trouble .
theraven is offline
Old 09-01-2006, 08:59 PM   #26 (permalink)
invisible
Posts: n/a
wtf
i have an old realtek LAN card
with the windows default drivers there is no option of changing MAC address.
With the new drivers the device mangaer allows me to change the MAC ID.
I would love to give the screeshots but just i dont have time for all this shiity.
I am able to clearly understand the problem now
@andy
what is the LAN card u r having?
Old 09-01-2006, 10:53 PM   #27 (permalink)
Default reply
wtf
@andy
Earlier Lancer which aided MAc address Change
Now i have Techcom which nolonger has the property of mac change
Btw I was provided the Device Driver by the manufactures
Which is still the MOST recent Driver(i checked out that)
Secondly just bcoz with new driver u had installed helped to get that Mac address Property doesnt mean that it will be the case with everybody
Also let me share the recent exp of mine regarding the foresaid topics
i has seen a motherboard of INTEL which had inbuilt Lan with it
AS usual It didnt have MAc adress change property
Now visit any intel website and just tel me whether they are providing any updates to the Lan drivers or Not
I bet They wont
y cant u understand that for security reasons That property is no longer available with any of the Lan manufactures.
Andyiz is offline
Old 09-01-2006, 11:07 PM   #28 (permalink)
invisible
Posts: n/a
Default Re: reply
I bet They wont
This is horrible.wtf.wtf.wtf.wtf.
Intel doesnt make LAN cards.Thas why they dont provide support for LAN card drivers.
Their motherboards come with inbuilt other Company LAN cards like realtek etc.. U suck more than I do lol
and also what is the driver date of your Techcom.Tell the chip name embedded on it.
Old 10-01-2006, 01:11 PM   #29 (permalink)
Chill, guys.
Peace.
You are the gr8 in all that u could understand what andyiz wants to xplain. I have also checked the same and have found that some of the companies has disabled this feature for security reasons.
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
Old 10-01-2006, 04:47 PM   #30 (permalink)
Default Re: reply
I bet They wont
Same Prblm Again. Y dont u read carefully to wat i posted.
i never mentioned InTel Manfactures Lans
But if they are updates to the Lans drivers , INtel Would Take us to the Link. THis can be Any other LAn maufacturing Organisation
Just like INtel uses Soundmax OR Realtek Audio cards, If there are UPdates for the Same provided by the Orignal Manufactures, then INtel would Link us to the respective Website
THIS GUY IS A SCEPTIC NONSENSE.
Mods plz help me understand this NUT.
Using abusive language is a crime
just convey this to him( For WTF WTF WTF)
Andyiz is offline
