Old 05-01-2006, 03:52 PM   #1 (permalink)
Default unable to format hard disk partition
i have got bad sectors on drive c of my hard disk.
i tried quick format on the drive but the bad sectors are still there.
then tried a full format but it just stops in the middle.
what do i do now . is there a way out
plz tell in detail.
Shasta is offline
Old 05-01-2006, 06:18 PM   #2 (permalink)
use OEM tool for your hard drive to format and create partitions, whatever you like
For seagate drive, use Disk manager.Search for it at Seagate site
Baroon is offline
Old 05-01-2006, 06:49 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
A format doesnt remove bad sectors if I am right
Harsh J
www.harshj.com
QwertyManiac is offline
Old 05-01-2006, 08:37 PM   #4 (permalink)
invisible
Posts: n/a
Default Re: unable to format hard disk partition
plz tell in detail.
u can use ranish partiton manager.which is a dos based program(part.exe).Just google for it.
Old 05-01-2006, 08:40 PM   #5 (permalink)
invisible
Posts: n/a
whats your age?
Old 05-01-2006, 10:20 PM   #6 (permalink)
Default Reply
First Use HDDlife to find Life of ur Hard drive, if its satisfactory then use any partition manager and try and solve ur problem.
If the life is unsatisfactory then better go for the new one bcoz Formatting ur hard drive again will do no good to ur Life of ur Hard drive
and worsen the situation
Andyiz is offline
Old 05-01-2006, 11:25 PM   #7 (permalink)
Will scandisk eliminate some bad sectors? There is an option on it but I didn't used it since I didn't have any bad sectors.
Yesterday - Dead
Today - Dying
Tomorrow - Never dies
The day after tomorrow - Where will you be !
Sreekanth V is offline
Old 06-01-2006, 07:50 PM   #8 (permalink)
scandisk only detects and marks ur bad sectors............. which means those paarticular sectors are discarded and are not used for reading/writing in future. the recovery options tries to copy the data present in those bad sectors to healthy sectors. scandisk won't remove the bad sectors. even formatting doesn't help much(i've heard that a low level format helps to some extent but i am not sure how to go round)........... bad sector is a bad sector and a disk with bad sectors is not reliable. time to get a new disk..........
satbir is offline
