Old 04-01-2006, 10:30 PM   #1 (permalink)
mario_pant's Avatar
Default how do i stay online 24/7?
hey i have dataone broadband with lovely speeds...
now what i wan to do is stay 24/7 online... but the problem is that i want to restrict internet acces to some 2 or 3 light transfer appz and restrict access by ALL other appz!
how do i achieve this...
well. the appz i want are mainly skype, MSNM, Y!M, Y! widget engine and azureus!
and another thing is that i want this restriction to be very flexible... i mean i will have to remove this restriction sometimes.....
and another requirement is the restriction to be timed.... i mean i want to remove it on 2:00 to 8:00.... well this time thing is a thing that i can do without though......
so do the DuDz at DiGiT/FoRuM have any solution?
The name is Mario, "Mario Pant"!
mario = avatar; pant = पतलून
and i'm NOT some mountain KiD!
mario_pant is offline
Old 04-01-2006, 11:18 PM   #2 (permalink)
siriusb's Avatar
What firewall do you have? With windows default sp2 firewall, you can go to control panel->Windows firewall-->Exceptions tab and add/check progs that you want to give access to. But it can't help with the timed restriction.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 04-01-2006, 11:28 PM   #3 (permalink)
mario_pant's Avatar
any software...?
cause changing the win xp firewall rules is not very handy and fast......
Old 05-01-2006, 07:34 AM   #4 (permalink)
shoegoe's Avatar
Hi!..amm.... i think u can try out zone alarm/ similar firewalls. Zone alarm will do good as its interface allows u to have more control over the files that access the net,.
And about limiting....maybe there are some banwitdth limiting options in your applications...azureus has such options... Try it out..
shoegoe is offline
Old 05-01-2006, 10:39 AM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
Try macros too Sometimes it works where no s/w is available Record a macro of givin rights and schedule it at 2:00 am and so on... agreed its not the best way out, but then too
Harsh J
www.harshj.com
QwertyManiac is offline
Old 05-01-2006, 10:49 AM   #6 (permalink)
ramprasad's Avatar
Try to search in the options for those particular s/w which doesnt need frequent connections
ramprasad is offline
Old 05-01-2006, 07:28 PM   #7 (permalink)
godsownman's Avatar
I have never used this software just heard and read about it .
Netlimiter is the name .
Try Google for more details.
Regards
godsownman is offline
Old 06-01-2006, 11:51 AM   #8 (permalink)
JGuru's Avatar
Use firewall called ZoneAlarm. It can allow or block
programs that connect to the Net.
It's the best firewall out there.
JGuru is offline
