Old 04-01-2006, 09:46 PM   #1 (permalink)
Default MAxtor 160G HDD 100G unformatted space ..SAFE?
hi
i have recently added new maxtor 160GB hdd however my bios shows only 136GB ..so i installed patch from maxtor which enables 48bit addressing mode and safely(?) transfers data to HDD.and after intalling my XP started to recognise as 151GB hDD now here i need to ask that if is it a correct way to use my hdd with this small software from maxtor...bcoz my assembler told me that if u use your hdd as is then it may develope bad sectors as my mobo doesnot support this much large capacity.
Also i am only using..as of now 50GB of 151 gb in two partitions..and rest is unformatted space...is it safe?
or should i format remaing space also eventhough asof now i dont need it..
thanx
P4 1.6Ghz,768MB SDRAM , on i845 mobo ,Philips 150S4 lcd on sis 315 Pro with 128MB VRAM ,40GB ATA100 5.4K rpm HDD,wifi enabled.hate sound card
hippi is offline
Old 04-01-2006, 09:49 PM   #2 (permalink)
hey 845 do supports 160 GB hard disk i m using it and as for unformatted space.. dont know if its bad but i also have 10 gb unformatted
Shwetanshu Srivastava
shwetanshu is offline
Old 04-01-2006, 09:58 PM   #3 (permalink)
i think my BIOS version is old...my mobo is 2002 manufacture..so it supports only 136GB i guess
but is it safe is the MAIN question
hippi is offline
Old 06-01-2006, 04:44 PM   #4 (permalink)
JGuru's Avatar
There is nothing wrong with unformatted space.
But it's better you format them.
The OS utilities try to fix the problems
in the formatted region only!!
:roll: :roll:
JGuru is offline
