Old 04-01-2006, 09:38 PM   #1 (permalink)
Default help.about blue screens.random messages.no hibernation
Hi
Actually i searched this forum before posting this..i found many similar threads but none of them match the ENTIRE problem of mine
here it goes...
I have P4 1.6Ghz intel 845 based mobo from ibrain company(is it bogus?)
all other specs r attached at the end....its from everest home edition
i use ZONEALARM AS AV SOFT AND FIREWALL
also now i am using LAN card for mtnl triband connection
for past few MONTHS i am encountering this problem
initially my pc used to freeze and used to give blue screens with random error message..random bcoz...there were 5-6 different types pf error messages
1.BAD_POOLER_TYPE
2.IRQL_LESS_THAN_EQUAL
3.PAGE_FUALT_IN_NON_PAGED_AREA (something like this)
4.somethihng like MEMORY_.... donno exact
and when no such error message apeears
stop error is displayed with usual stuuf like windows has been shut down to prevent damage.....
sometimes name of one file win2k2.sys is also displayed and sometimes imapi.dll
one of the stop error message is
STOP: 0x0000008E(0xC0000005 , 0x8054B907, 0xF3EF4C2C, 0x00000000)
this stop address varies everytime
initially i used to get it netime ...after some days my copy of XP fot corrupted i installed fresh one on same partition without formatting...
ie overwrote existing windows folder of corrupted XP.
afer that my pc started crashing only while starting..checked at ms site but its trouleshooting didnt help...every time i had to hard reboot my pc twice after that it used to work fine .. then i staretd hibernating my comp ..initially hibernation was working...but after few weeks it stopped working ie it used to go to hibernation but while resumung i used to get blue screen so i REINSTALLED win XP (not fresh copy) worked fine for couple of restarts ...
but problem started again
now there is lue screen also and sometimes some "tuck" sound comes from one of the HDD and pc freezes (no blue screens) specially while playing simcity
i cleaned my both memory sticks and reinserted it but no effect.
i dont overclock or change memory latency except my 256 mb memory is PC133 and 512Mb is PC100 and overall system is set for 100Mhz
i have Dlink lan card and Geforce fx 5200 AGP card
but friend who doesnot have ne of above is also facing same problem with same symptoms(identical)
Please tell us some solution about this problem
URGENT....PLZ
Report of <HOME>EVEREST Home Edition © 2003-2005 Lavalys, Inc.
Version EVEREST v2.01.347
Homepage http://www.lavalys.com/
Report Type Report Wizard
Computer HOME
Generator ***********
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP
Retail)
Date 2005-10-11
Time 13:50
Summary
Computer:
OS Service Pack Service Pack 2
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name HOME
User Name Suhas Bhirud
Motherboard:
CPU Type Intel Pentium 4, 1600 MHz (16 x 100)
Motherboard Name Unknown
Motherboard Chipset Intel Brookdale i845
System Memory 768 MB (SDRAM)
BIOS Type Award Modular (12/14/01)
Communication Port Communications Port (COM1)
Communication Port Communications Port (COM2)
Communication Port Bluetooth Communications Port (COM3)
Communication Port ECP Printer Port (LPT1)
Display:
Video Adapter NVIDIA GeForce FX 5200 (128 MB)
3D Accelerator nVIDIA GeForce FX 5200
Monitor Philips 150S4 [15" LCD] (CX 276482)
Multimedia:
Audio Adapter Intel 82801BA(M) ICH2 - AC'97 Audio Controller [B-5]
Storage:
IDE Controller Intel(R) 82801BA Ultra ATA Storage Controller - 244B
Floppy Drive Floppy disk drive
Disk Drive SAMSUNG SV4002H (40 GB, 5400 RPM, Ultra-ATA/100)
Disk Drive QUANTUM FIREBALL EX6.4A (6 GB, 5400 RPM, Ultra-ATA/33)
Optical Drive ASUS CRW-2410A (24x/10x/40x CD-RW)
Optical Drive ASUS DVD-ROM E616 (16x/48x DVD-ROM)
SMART Hard Disks Status OK
Partitions: on SAMSUNG 40GB on primary master
C: (FAT32) 19114 MB
E: (FAT32) 19059 MB
Total Size 44315 MB
NOTE:i recntlly MAxtor 160GB HDD as primary slave
Input:
Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse PS/2 Compatible Mouse
Peripherals:
Printer Adobe PDF
Printer Canon Bubble-Jet BJC-210
Printer Microsoft Office Document Image Writer
USB1 Controller Intel 82801BA(M) ICH2 - USB Controller 1 [B-5]
USB1 Controller Intel 82801BA(M) ICH2 - USB Controller 2 [B-5]
DMI
[ BIOS ]
BIOS Properties:
Vendor Award Software International, Inc.
Version 6.00 PG
Release Date 12/14/2001
Size 256 KB
Boot Devices Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120
Capabilities Flash BIOS, Shadow BIOS, Selectable Boot, EDD
Supported Standards DMI, APM, ACPI, ESCD, PnP
Expansion Capabilities ISA, PCI, AGP, USB
[ System ]
System Properties:
Wake-Up Type Power Switch
[ Motherboard ]
Motherboard Properties:
Product i845-ITE8712
[ Chassis ]
Chassis Properties:
Chassis Type Desktop Case
[ Memory Controller ]
Memory Controller Properties:
Error Detection Method 8-bit Parity
Error Correction None
Supported Memory Interleave 1-Way
Current Memory Interleave 1-Way
Supported Memory Types ECC, SDRAM
Supported Memory Voltages 5V
Maximum Memory Module Size 1024 MB
Memory Slots 3
[ Processors / Intel Pentium(R) 4 ]
Processor Properties:
Manufacturer Intel
Version Intel Pentium(R) 4
External Clock 100 MHz
Maximum Clock 2400 MHz
Current Clock 1600 MHz
Type Central Processor
Status Enabled
Upgrade ZIF
Socket Designation Socket 478
[ Caches / Internal Cache ]
Cache Properties:
Type Internal
Status Enabled
Operational Mode Write-Back
Maximum Size 20 KB
Installed Size 20 KB
Supported SRAM Type Synchronous
Current SRAM Type Synchronous
Socket Designation Internal Cache
[ Caches / External Cache ]
Cache Properties:
Type External
Status Disabled
Maximum Size 512 KB
Installed Size 256 KB
Socket Designation External Cache
[ Memory Modules / A0 ]
Memory Module Properties:
Socket Designation A0
Type SDRAM
Installed Size 512 MB
Enabled Size 512 MB
[ Memory Modules / A1 ]
Socket Designation A1
Type SDRAM
Installed Size 256 MB
Enabled Size 256 MB
[ Memory Modules / A2 ]
Socket Designation A2
Type SDRAM
Installed Size Not Installed
Enabled Size Not Installed
[ Memory Devices / A0 ]
Memory Device Properties:
Form Factor DIMM
Type Detail Window DRAM
Size 512 MB
Total Width 72-bit
Data Width 68-bit
Device Locator A0
Bank Locator Bank0/1
[ Memory Devices / A1 ]
Form Factor DIMM
Size 256 MB
Total Width 64-bit
Data Width 64-bit
Device Locator A1
Bank Locator Bank2/3
[ Memory Devices / A2 ]
Form Factor DIMM
Device Locator A2
Bank Locator Bank4/5
[ System Slots / PCI ]
System Slot Properties:
Slot Designation PCI
Type PCI
Usage In Use
Data Bus Width 32-bit
Length Long
Type PCI
Usage In Use
Length Long
Type PCI
Usage Empty
Length Long
Type PCI
Usage Empty
Length Long
[ System Slots / AGP ]
Slot Designation AGP
Type AGP
Usage In Use
Length Long
[ Port Connectors / PRIMARY IDE ]
Port Connector Properties:
Internal Reference Designator PRIMARY IDE
Internal Connector Type On-Board IDE
External Connector Type None
[ Port Connectors / SECONDARY IDE ]
Internal Reference Designator SECONDARY IDE
[ Port Connectors / FDD ]
Port Type 8251 FIFO Compatible
Internal Reference Designator FDD
Internal Connector Type On-Board Floppy
[ Port Connectors / COM1 ]
Port Type Serial Port 16450 Compatible
Internal Reference Designator COM1
Internal Connector Type 9 Pin Dual Inline (pin 10 cut)
External Connector Type DB-9 pin male
[ Port Connectors / COM2 ]
Internal Reference Designator COM2
[ Port Connectors / LPT1 ]
Port Type Parallel Port ECP/EPP
Internal Reference Designator LPT1
Internal Connector Type DB-25 pin female
External Connector Type DB-25 pin female
[ Port Connectors / Keyboard ]
Port Type Keyboard Port
Internal Reference Designator Keyboard
External Connector Type PS/2
[ Port Connectors / Detected ]
Port Type Mouse Port
Internal Reference Designator PS/2 Mouse
Internal Connector Type PS/2
External Reference Designator Detected
[ Port Connectors / USB ]
Port Type USB
Internal Reference Designator USB
Internal Connector Type None
Port Type USB
Overclock
CPU Properties:
CPU Alias P68, Willamette, A80528
CPU Stepping D0
Engineering Sample No
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 1.60GHz
CPUID Revision 00000F12h
CPU Speed:
CPU Clock 1594.00 MHz (original: 1600 MHz)
CPU Multiplier 16.0x
CPU FSB 99.63 MHz (original: 100 MHz)
Memory Bus 99.63 MHz
CPU Cache:
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 256 KB (On-Die, ECC, ATC, Full-Speed)
Motherboard ID 12/14/2001-i845-ITE8712-ATC8060C-GX
Chipset Properties:
Memory Timings 3-2-2-5 (CL-RCD-RP-RAS)
SPD Memory Modules:
DIMM1: Kingston KGM100x72RC3/512 512 MB PC100 ECC SDRAM (3.0-2-2-5 @ 100
MHz)
DIMM2: Micron Tech. 256 MB PC133 SDRAM (3.0-3-3-6 @ 133 MHz)
BIOS Properties:
System BIOS Date 12/14/01
Video BIOS Date 01/27/04
Award BIOS Type Award Modular BIOS v6.00PG
Award BIOS Message ATC8060 P4/478 i845/ICH2 Rev:1.0r02
DMI BIOS Version 6.00 PG
Graphics Processor Properties:
Video Adapter Pine Tech. GeForce FX 5200
GPU Code Name NV34 (AGP 4x 10DE / 0322, Rev A1)
GPU Clock 132 MHz
Memory Clock 88 MHz
Power Management
Power Management Properties:
Current Power Source AC Line
Battery Status No Battery
Full Battery Lifetime Unknown
Remaining Battery Lifetime Unknown
Sensor
Sensor Properties:
Sensor Type ITE IT8705F (ISA 290h)
Temperatures:
Motherboard 53 °C (127 °F)
Aux 49 °C (120 °F)
SAMSUNG SV4002H 39 °C (102 °F)
Cooling Fans:
CPU 4299 RPM
Voltage Values:
CPU Core 1.70 V
+2.5 V 1.28 V
+3.3 V 3.23 V
+5 V 5.19 V
+12 V 11.90 V
+5 V Standby 2.58 V
VBAT Battery 3.02 V
Debug Info V 6A 50 CA C1 BA 44 72 60 (33)
Debug Info T 49 53 201
CPU
CPU Properties:
CPU Stepping D0
Instruction Set x86, MMX, SSE, SSE2
Original Clock 1600 MHz
L1 Data Cache 8 KB
CPU Physical Info:
Package Type 478 Pin uPGA
Package Size 3.50 cm x 3.50 cm
Transistors 42 million
Process Technology 6M, 0.18 um, CMOS
Die Size 217 mm2
Core Voltage 1.75 V
I/O Voltage 1.75 V
Typical Power 55.3 - 75.3 W (depending on clock speed)
Maximum Power 72 - 100 W (depending on clock speed)
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/processor.htm
CPU Utilization:
CPU #1 5 %
CPUID
CPUID Properties:
CPUID Manufacturer GenuineIntel
IA Brand ID 08h (Intel Pentium 4)
Platform ID 0Eh (Socket 478)
IA CPU Serial Number Unknown
Microcode Update Revision 2E
HTT / CMP Units 0 / 0
Instruction Set:
64-bit x86 Extension (AMD64, EM64T) Not Supported
Alternate Instruction Set Not Supported
AMD 3DNow! Not Supported
AMD 3DNow! Professional Not Supported
AMD Enhanced 3DNow! Not Supported
AMD Extended MMX Not Supported
Cyrix Extended MMX Not Supported
IA-64 Not Supported
IA MMX Supported
IA SSE Supported
IA SSE 2 Supported
IA SSE 3 Not Supported
CLFLUSH Instruction Supported
CMPXCHG8B Instruction Supported
CMPXCHG16B Instruction Not Supported
Conditional Move Instruction Supported
FEMMS Instruction Not Supported
MONITOR / MWAIT Instruction Not Supported
RDTSCP Instruction Not Supported
SYSCALL / SYSRET Instruction Not Supported
SYSENTER / SYSEXIT Instruction Supported
Security Features:
Advanced Cryptography Engine (ACE) Not Supported
Data Execution Prevention (DEP, NX, EDB) Not Supported
Hardware Random Number Generator (RNG) Not Supported
Montgomery Multiplier & Hash Engine Not Supported
Processor Serial Number (PSN) Not Supported
Power Management Features:
Automatic Clock Control Supported
Enhanced Halt State (C1E) Not Supported
Enhanced SpeedStep Technology (EIST, ESS) Not Supported
Frequency ID Control Not Supported
LongRun Not Supported
LongRun Table Interface Not Supported
PowerSaver 1.0 Not Supported
PowerSaver 2.0 Not Supported
PowerSaver 3.0 Not Supported
Processor Duty Cycle Control Supported
Software Thermal Control Not Supported
Temperature Sensing Diode Not Supported
Thermal Monitor 1 Supported
Thermal Monitor 2 Not Supported
Thermal Monitoring Not Supported
Thermal Trip Not Supported
Voltage ID Control Not Supported
CPUID Features:
36-bit Page Size Extension Supported
CPL Qualified Debug Store Not Supported
Debug Trace Store Supported
Debugging Extension Supported
Fast Save & Restore Supported
Hyper-Threading Technology Not Supported
L1 Context ID Not Supported
Local APIC On Chip Supported
Machine-Check Architecture Supported
Machine-Check Exception Supported
Memory Type Range Registers Supported
Model Specific Registers Supported
Page Attribute Table Supported
Page Global Extension Supported
Pending Break Event Not Supported
Physical Address Extension Supported
Secure Virtual Machine Extensions (Pacifica) Not Supported
Self-Snoop Supported
Time Stamp Counter Supported
Virtual Machine Extensions (Vanderpool) Not Supported
Virtual Mode Extension Supported
CPUID Registers (CPU #1):
CPUID 00000000 00000002-756E6547-6C65746E-49656E69
CPUID 00000001 00000F12-00010808-00000000-3FEBFBFF
CPUID 00000002 665B5001-00000000-00000000-007A7040
CPUID 80000000 80000004-00000000-00000000-00000000
CPUID 80000001 00000000-00000000-00000000-00000000
CPUID 80000002 20202020-20202020-20202020-6E492020
CPUID 80000003 286C6574-50202952-69746E65-52286D75
CPUID 80000004 20342029-20555043-30362E31-007A4847
MSR Registers:
MSR 00000017 0008-0000-0000-0000
MSR 0000002A 0000-0000-0000-4000
MSR 0000002C 0000-0000-8201-FF00
MSR 0000011E 0000-0000-0000-0000
MSR C0000087 0000-0000-0000-0000
MSR C0010015 0000-0000-0000-0000
MSR 0000010A 0000-0000-0000-0000
MSR C0010042 0000-0000-0000-0000
MSR 000000CD 0000-0000-0000-0000
MSR 0000008B 0000-002E-0000-0000
MSR 0000019A 0000-0000-0000-0008
MSR 0000019B 0000-0000-0000-0000
MSR 0000019C 0000-0000-0000-0000
MSR 000001A0 0000-0000-0000-00E9
Motherboard
Front Side Bus Properties:
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 100 MHz (QDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Memory Bus Properties:
Bus Type SDR SDRAM
Bus Width 64-bit
Real Clock 100 MHz
Effective Clock 100 MHz
Bandwidth 800 MB/s
Chipset Bus Properties:
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Effective Clock 267 MHz
Bandwidth 267 MB/s
Memory
Physical Memory:
Total 767 MB
Used 282 MB
Free 485 MB
Utilization 37 %
Swap Space:
Total 1876 MB
Used 239 MB
Free 1636 MB
Utilization 13 %
Virtual Memory:
Total 2644 MB
Used 521 MB
Free 2122 MB
Utilization 20 %
Physical Address Extension (PAE):
Supported by Operating System Yes
Supported by CPU Yes
Active No
SPD
[ DIMM1: Kingston KGM100x72RC3/512 ]
Module Name Kingston KGM100x72RC3/512
Serial Number 25121900h
Manufacture Date Week 37 / 2001
Module Size 512 MB (1 rows, 4 banks)
Module Type Registered
Memory Type SDRAM
Memory Speed PC100 (100 MHz)
Module Width 72 bit
Module Voltage LVTTL
Error Detection Method ECC
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings:
@ 100 MHz 3.0-2-2-5 (CL-RCD-RP-RAS)
Memory Module Features:
Early RAS# Precharge Not Supported
Auto-Precharge Supported
Precharge All Supported
Write1/Read Burst Supported
Buffered Address/Control Inputs Supported
Registered Address/Control Inputs Supported
On-Card PLL (Clock) Supported
Buffered DQMB Inputs Supported
Registered DQMB Inputs Supported
Differential Clock Input Not Supported
Redundant Row Address Not Supported
Memory Module Manufacturer:
Company Name Kingston Technology Company, Inc.
Product Information http://www.kingston.com/products/default.asp
[ DIMM2: Micron Tech. (256 MB PC133 SDRAM) ]
Module Name Micron Tech.
Serial Number None
Module Size 256 MB (2 rows, 4 banks)
Module Type Unbuffered
Memory Type SDRAM
Memory Speed PC133 (133 MHz)
Module Width 64 bit
Error Detection Method None
Refresh Rate Normal (15.625 us), Self-Refresh
Memory Timings:
@ 133 MHz 3.0-3-3-6 (CL-RCD-RP-RAS)
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Company Name Micron Technology, Inc.
Product Information
http://www.micron.com/products/category.jsp?path=/DRAM
Chipset
[ North Bridge: Intel Brookdale i845 ]
North Bridge Properties:
North Bridge Intel Brookdale i845
Revision 04
Package Type 593 Pin FC-BGA
Package Size 3.75 cm x 3.75 cm
Core Voltage 1.5 V
In-Order Queue Depth 12
Memory Timings:
CAS Latency (CL) 3T
RAS To CAS Delay (tRCD) 2T
RAS Precharge (tRP) 2T
RAS Active Time (tRAS) 5T
Error Correction:
ECC Supported, Disabled
ChipKill ECC Not Supported
ECC Scrubbing Not Supported
Memory Slots:
DRAM Slot #1 512 MB (SDRAM)
DRAM Slot #2 256 MB (SDRAM)
AGP Controller:
AGP Version 2.00
AGP Status Enabled
AGP Device Pine Tech. GeForce FX 5200
AGP Aperture Size 128 MB
Supported AGP Speeds 1x, 2x, 4x
Current AGP Speed 4x
Fast-Write Supported, Enabled
Side Band Addressing Supported, Enabled
Chipset Manufacturer:
Product Information http://www.intel.com/products/browse/chipsets.htm
Driver Download http://support.intel.com/support/chipsets/index.htm
[ South Bridge: Intel 82801BA ICH2 ]
South Bridge Properties:
South Bridge Intel 82801BA ICH2
Revision / Stepping 05 / B5
Package Type 360 Pin EBGA
Package Size 2.3 cm x 2.3 cm
Core Voltage 1.8 V
AC'97 Audio Controller:
Audio Controller Type Intel 82801BA(M) ICH2
Codec Name Avance Logic ALC101
Codec ID 414C4730h
S/PDIF Output Not Supported
BIOS
BIOS Properties:
BIOS Manufacturer:
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
BIOS Upgrades http://www.esupport.com/biosagent/in...m?refererid=40
Problems & Suggestions:
Suggestion Are you looking for a BIOS Upgrade? Contact eSupport Today!
Suggestion System BIOS is more than 2 years old. Update it if necessary.
Windows Video
[ NVIDIA GeForce FX 5200 ]
Video Adapter Properties:
Device Description NVIDIA GeForce FX 5200
Adapter String GeForce FX 5200
BIOS String Version 4.34.20.67.00
Chip Type GeForce FX 5200
DAC Type Integrated RAMDAC
Installed Drivers nv4_disp (6.14.10.7801 - nVIDIA ForceWare 78.01)
Memory Size 128 MB
Video Adapter Manufacturer:
Company Name NVIDIA Corporation
Product Information http://www.nvidia.com/view.asp?PAGE=products
Driver Download http://www.nvidia.com/drivers
PCI / AGP Video
Device Description Device Type
nVIDIA GeForce FX 5200 Video Adapter
nVIDIA GeForce FX 5200 3D Accelerator
GPU
[ AGP 4x: Pine Tech. GeForce FX 5200 ]
GPU Code Name NV34
PCI Device 10DE / 0322
Transistors 47 million
Process Technology 0.15u
Bus Type AGP 4x
Memory Size 128 MB
GPU Clock 132 MHz
RAMDAC Clock 350 MHz
Pixel Pipelines 4
TMU Per Pipeline 1
Vertex Shaders 2 (v2.0)
Pixel Shaders 1 (v2.0)
DirectX Hardware Support DirectX v9.0
Pixel Fillrate 528 MPixel/s
Texel Fillrate 528 MTexel/s
Bus Type DDR
Bus Width 64-bit
Real Clock 88 MHz (DDR)
Effective Clock 177 MHz
Bandwidth 1416 MB/s
Graphics Processor Manufacturer:
nVIDIA Registers:
nv-000000 034200B1
nv-100000 00000000
nv-100200 19D10001
nv-10020C 08000000
nv-101000 A0C0E0DF
nv-680500 00012502
nv-680504 00014A03
nv-680570 00000401
nv-680574 00000401
nv-68057C 80000701
Monitor
[ Philips 150S4 ]
Monitor Properties:
Monitor Name Philips 150S4
Monitor ID PHL0812
Model Philips 150S
Monitor Type 15" LCD
Manufacture Date Week 31 / 2003
Serial Number CX 276482
Max. Visible Display Size 30 cm x 23 cm (14.9")
Picture Aspect Ratio 4:3
Horizontal Frequency 30 - 63 kHz
Vertical Frequency 56 - 76 Hz
Maximum Resolution 1024 x 768
Gamma 2.20
DPMS Mode Support Standby, Suspend, Active-Off
Supported Video Modes:
640 x 480 76 Hz
800 x 600 76 Hz
1024 x 768 75 Hz
Monitor Manufacturer:
Company Name Royal Philips Electronics
Product Information
http://www.consumer.philips.com/glob...PC_MONITORS_CA
Driver Download
http://www2.consumer.philips.com/glo...1_74&strokeId=
Desktop
Desktop Properties:
Device Technology Raster Display
Color Depth 32-bit
Color Planes 1
Font Resolution 96 dpi
Pixel Width / Height 36 / 36
Pixel Diagonal 51
Vertical Refresh Rate 60 Hz
Desktop Wallpaper E:\Documents and Settings\Suhas Bhirud.HOME\Application
Desktop Effects:
Combo-Box Animation Enabled
Drop Shadow Effect Enabled
Flat Menu Effect Enabled
Font Smoothing Enabled
Full Window Dragging Enabled
Gradient Window Title Bars Enabled
Hide Menu Access Keys Enabled
Hot Tracking Effect Enabled
Icon Title Wrapping Enabled
List-Box Smooth Scrolling Enabled
Menu Animation Enabled
Menu Fade Effect Enabled
Minimize/Restore Animation Enabled
Mouse Cursor Shadow Enabled
Selection Fade Effect Enabled
ShowSounds Accessibility Feature Disabled
ToolTip Animation Enabled
ToolTip Fade Effect Enabled
Windows Plus! Extension Disabled
Problem At least 85 Hz vertical refresh rate is recommended for classic
(CRT) displays.
Multi-Monitor
Device ID Primary Upper Left Corner Bottom Right Corner
\\.\DISPLAY1 Yes (0,0) (1024,768)
Windows Audio
Device Identifier Device Description
midi-in.0 0001 0067 MPU-401
midi-out.0 0001 0066 Microsoft GS Wavetable SW Synth
midi-out.1 0001 0066 MPU-401
mixer.0 0001 0068 Intel(r) Integrated Audio
mixer.1 0001 0068 Bluetooth Audio
wave-in.0 0001 0065 Intel(r) Integrated Audio
wave-in.1 0001 0065 Bluetooth Audio
wave-out.0 0001 0064 Intel(r) Integrated Audio
wave-out.1 0001 0064 Bluetooth Audio
PCI / PnP Audio
Device Description Type
Intel 82801BA(M) ICH2 - AC'97 Audio Controller [B-5] PCI
Windows Storage
[ Floppy disk drive ]
Device Properties:
Driver Description Floppy disk drive
Driver Date 01-Jul-01
Driver Version 5.1.2600.0
Driver Provider Microsoft
INF File flpydisk.inf
[ QUANTUM FIREBALL EX6.4A ]
Device Properties:
Driver Description QUANTUM FIREBALL EX6.4A
Driver Version 5.1.2535.0
INF File disk.inf
Disk Device Physical Info:
Manufacturer Quantum
Hard Disk Family Fireball EX
Family Code Name Eclipse Plus
Form Factor 3.5"
Formatted Capacity 6448 million bytes
Disks 2
Recording Surfaces 4
Physical Dimensions 146.1 x 101.6 x 25.4 mm
Max. Weight 492 g
Average Rotational Latency 5.56 ms
Rotational Speed 5400 RPM
Max. Internal Data Rate 187 Mbit/s
Average Seek 9.5 ms
Track-To-Track Seek 2 ms
Full Seek 18 ms
Interface Ultra-ATA/33
Buffer-to-Host Data Rate 33.3 MB/s
Buffer Size 512 KB
Spin-Up Time 9.5 sec
Device Manufacturer:
Company Name Maxtor Corporation
Product Information http://www.maxtor.com/en/products/
[ SAMSUNG SV4002H ]
Device Properties:
Driver Description SAMSUNG SV4002H
INF File disk.inf
Manufacturer Samsung
Hard Disk Family SpinPoint V40
Form Factor 3.5"
Formatted Capacity 40 GB
Disks 1
Recording Surfaces 2
Physical Dimensions 146.0 x 101.6 x 25.4 mm
Max. Weight 635 g
Max. Internal Data Rate 443 Mbit/s
Average Seek 8.9 ms
Track-To-Track Seek 0.8 ms
Full Seek 16.5 ms
Interface Ultra-ATA/100
Buffer-to-Host Data Rate 100 MB/s
Buffer Size 2 MB
Spin-Up Time 10 sec
Company Name Samsung
Product Information
http://www.samsung.com/Products/HardDiskDrive/index.htm
[ ASUS CRW-2410A ]
Device Properties:
Driver Description ASUS CRW-2410A
INF File cdrom.inf
Optical Drive Properties:
Manufacturer Asus
Device Type CD-RW
Speed 24x/10x/40x
Company Name ASUSTeK Computer Inc.
Product Information http://www.asus.com/products1.aspx?l1=6
Firmware Download
http://www.asus.com/support/download...ct&item=DVD-RW
[ ASUS DVD-ROM E616 ]
Device Properties:
Driver Description ASUS DVD-ROM E616
INF File cdrom.inf
Manufacturer Asus
Device Type DVD-ROM
Speed 16x/48x
Firmware Download
[ Intel(R) 82801BA Ultra ATA Storage Controller - 244B ]
Device Properties:
Driver Description Intel(R) 82801BA Ultra ATA Storage Controller - 244B
Driver Version 5.1.2600.2180
INF File mshdc.inf
Device Resources:
Port F000-F00F
[ Primary IDE Channel ]
Device Properties:
Driver Description Primary IDE Channel
INF File mshdc.inf
Device Resources:
IRQ 14
Port 01F0-01F7
Port 03F6-03F6
[ Secondary IDE Channel ]
Device Properties:
Driver Description Secondary IDE Channel
INF File mshdc.inf
Device Resources:
IRQ 15
Port 0170-0177
Port 0376-0376
[ Standard floppy disk controller ]
Device Properties:
Driver Description Standard floppy disk controller
INF File fdc.inf
Device Resources:
DMA 02
IRQ 06
Port 03F0-03F5
Port 03F7-03F7
Logical Drives
Drive Drive Type File System Total Size Used Space Free Space % Free
Volume Serial
A: Removable Disk
C: (SUHAS) Local Disk FAT32 19114 MB 16790 MB 2324 MB 12 %
242B-13F7
D: Local Disk NTFS 6142 MB 5352 MB 789 MB 13 % 64D5-AAB3
E: (BACKUP) Local Disk FAT32 19059 MB 16565 MB 2494 MB 13 %
3877-9929
F: (CHIPTOOLSV2I10) Optical Drive CDFS 610 MB 610 MB 0 KB 0 %
1560-4B52
G: Optical Drive
Physical Drives
[ Drive #1 - SAMSUNG SV4002H (37 GB) ]
Partition Partition Type Drive Start Offset Partition Length
#1 (Active) FAT32 C: (SUHAS) 0 MB 19124 MB
#2 FAT32 E: (BACKUP) 19124 MB 19069 MB
[ Drive #2 - QUANTUM FIREBALL EX6.4A (6150 MB) ]
#1 NTFS D: 0 MB 6142 MB
Optical Drives
[ ASUS CRW-2410A ]
Device Description ASUS CRW-2410A
Manufacturer Asus
Device Type CD-RW
Speed 24x/10x/40x
Firmware Download
Device Description ASUS DVD-ROM E616
Manufacturer Asus
Device Type DVD-ROM
Speed 16x/48x
Firmware Download
ASPI
Host ID LUN Device Type Vendor Model Rev Extra Information
00 00 00 Disk Drive SAMSUNG SV4002H
00 01 00 Disk Drive QUANTUM FIREBALL EX6.4A
00 07 00 Host Adapter atapi
01 00 00 Optical Drive ASUS CRW -2410A
01 01 00 Optical Drive ASUS DVD -ROM E616
01 07 00 Host Adapter atapi
ATA
[ SAMSUNG SV4002H (0358J1FT329668) ]
ATA Device Properties:
Model ID SAMSUNG SV4002H
Serial Number 0358J1FT329668
Revision QP200-05
Parameters 77622 cylinders, 16 heads, 63 sectors per track, 619 bytes per
sector
LBA Sectors 78242976
Buffer 1945 KB (Dual Ported, Read Ahead)
Multiple Sectors 16
ECC Bytes 4
Max. PIO Transfer Mode PIO 4
Max. UDMA Transfer Mode UDMA 5 (ATA-100)
Active UDMA Transfer Mode UDMA 5 (ATA-100)
Unformatted Capacity 46189 MB
ATA Device Features:
SMART Supported
Security Mode Supported
Power Management Supported
Advanced Power Management Not Supported
Write Cache Supported
Host Protected Area Supported
Power-Up In Standby Not Supported
Automatic Acoustic Management Supported
48-bit LBA Not Supported
Device Configuration Overlay Not Supported
ATA Device Physical Info:
Form Factor 3.5"
Disks 1
Max. Weight 635 g
Average Seek 8.9 ms
Full Seek 16.5 ms
Buffer Size 2 MB
Spin-Up Time 10 sec
ATA Device Manufacturer:
Product Information
SMART
ID Attribute Description Threshold Value Worst Data Status
01 Raw Read Error Rate 0 100 100 279 OK: Always passing
04 Start/Stop Count 0 97 97 3371 OK: Always passing
05 Reallocated Sector Count 9 99 99 13 OK: Value is normal
07 Seek Error Rate 51 253 253 0 OK: Value is normal
08 Seek Time Performance 0 253 253 0 OK: Always passing
09 Power-On Time Count 0 100 100 215636 OK: Always passing
0C Power Cycle Count 0 99 99 1752 OK: Always passing
C2 Temperature 0 121 91 39 OK: Always passing
C5 Current Pending Sector Count 9 253 253 0 OK: Value is normal
C6 Off-Line Uncorrectable Sector Count 9 253 253 0 OK: Value is
normal
C7 Ultra ATA CRC Error Rate 0 200 200 0 OK: Always passing
C8 Write Error Rate 51 100 100 11 OK: Value is normal
C9 <vendor-specific> 51 100 100 0 OK: Value is normal
PCI / PnP Network
D-Link RTL8139(A/B/C)-based Fast Ethernet Adapter PCI
DirectX Video
[ Primary Display Driver ]
DirectDraw Device Properties:
DirectDraw Driver Name display
DirectDraw Driver Description Primary Display Driver
Hardware Driver nv4_disp.dll
Hardware Description NVIDIA GeForce FX 5200
Direct3D Device Properties:
Available Local Video Memory 126976 KB
Available Non-Local Video Memory (AGP) 120831 KB
Rendering Bit Depths 16, 32
Z-Buffer Bit Depths 16, 24
Min Texture Size 1 x 1
Max Texture Size 4096 x 4096
Vertex Shader Version 2.0
Pixel Shader Version 2.0
Direct3D Device Features:
Additive Texture Blending Supported
AGP Texturing Supported
Anisotropic Filtering Supported
Bilinear Filtering Supported
Cubic Environment Mapping Supported
Cubic Filtering Not Supported
Decal-Alpha Texture Blending Supported
Decal Texture Blending Supported
Directional Lights Not Supported
DirectX Texture Compression Supported
DirectX Volumetric Texture Compression Not Supported
Dithering Supported
Dot3 Texture Blending Supported
Dynamic Textures Supported
Edge Antialiasing Supported
Environmental Bump Mapping Supported
Environmental Bump Mapping + Luminance Supported
Factor Alpha Blending Supported
Geometric Hidden-Surface Removal Not Supported
Guard Band Supported
Hardware Scene Rasterization Supported
Hardware Transform & Lighting Supported
Legacy Depth Bias Not Supported
Mipmap LOD Bias Adjustments Supported
Mipmapped Cube Textures Supported
Mipmapped Volume Textures Supported
Modulate-Alpha Texture Blending Supported
Modulate Texture Blending Supported
Non-Square Textures Supported
N-Patches Not Supported
Perspective Texture Correction Supported
Point Lights Not Supported
Point Sampling Supported
Projective Textures Supported
Quintic Bezier Curves & B-Splines Not Supported
Range-Based Fog Supported
Rectangular & Triangular Patches Not Supported
Rendering In Windowed Mode Supported
Scissor Test Not Supported
Slope-Scale Based Depth Bias Not Supported
Specular Flat Shading Supported
Specular Gouraud Shading Supported
Specular Phong Shading Not Supported
Spherical Mapping Supported
Spot Lights Not Supported
Stencil Buffers Supported
Sub-Pixel Accuracy Supported
Table Fog Supported
Texture Alpha Blending Supported
Texture Clamping Supported
Texture Mirroring Supported
Texture Transparency Supported
Texture Wrapping Supported
Triangle Culling Not Supported
Trilinear Filtering Supported
Two-Sided Stencil Test Not Supported
Vertex Alpha Blending Supported
Vertex Fog Supported
Vertex Tweening Not Supported
W-Based Fog Supported
W-Buffering Not Supported
Z-Based Fog Supported
Z-Bias Supported
Z-Test Supported
Supported FourCC Codes:
4x16 Supported
4x32 Supported
DXT1 Supported
DXT2 Supported
DXT3 Supported
DXT4 Supported
DXT5 Supported
IF09 Supported
IV31 Supported
IV32 Supported
NV12 Supported
NVBF Supported
NVCS Supported
NVHS Supported
NVHU Supported
RAW8 Supported
UYVY Supported
YUY2 Supported
YV12 Supported
YVU9 Supported
DirectX Sound
[ Primary Sound Driver ]
DirectSound Device Properties:
Device Description Primary Sound Driver
Driver Module
Primary Buffers 1
Min / Max Secondary Buffers Sample Rate 48000 / 48000 Hz
Primary Buffers Sound Formats 16-bit, Mono, Stereo
Secondary Buffers Sound Formats 16-bit, Mono, Stereo
Total / Free Sound Buffers 1 / 0
Total / Free Static Sound Buffers 1 / 0
Total / Free Streaming Sound Buffers 1 / 0
Total / Free 3D Sound Buffers 0 / 0
Total / Free 3D Static Sound Buffers 0 / 0
Total / Free 3D Streaming Sound Buffers 0 / 0
DirectSound Device Features:
Certified Driver Yes
Emulated Device No
Precise Sample Rate Supported
DirectSound3D Not Supported
Creative EAX 1.0 Not Supported
Creative EAX 2.0 Not Supported
Creative EAX 3.0 Not Supported
[ Intel(r) Integrated Audio ]
Device Description Intel(r) Integrated Audio
Driver Module ac97intc.sys
Primary Buffers 1
Emulated Device No
[ Bluetooth Audio ]
Device Description Bluetooth Audio
Driver Module btaudio.sys
Primary Buffers 1
Min / Max Secondary Buffers Sample Rate 100 / 200000 Hz
Primary Buffers Sound Formats 8-bit, 16-bit, Mono, Stereo
Secondary Buffers Sound Formats 8-bit, 16-bit, Mono, Stereo
Total / Free Sound Buffers 0 / 0
Total / Free Static Sound Buffers 0 / 0
Total / Free Streaming Sound Buffers 0 / 0
Emulated Device No
DirectX Music
[ MPU-401 ]
DirectMusic Device Properties:
Device Description MPU-401
Synthesizer Type Hardware
Device Class Input Port
Device Type WDM Multimedia
MIDI Channels 16
DirectMusic Device Features:
Built-In GM Instrument Set No
Built-In Roland GS Sound Set No
DirectSound Not Supported
DLS L1 Sample Collections Not Supported
DLS L2 Sample Collections Not Supported
External MIDI Port Yes
Fixed DLS Memory Size No
Port Sharing Not Supported
Chorus Effect Not Supported
Delay Effect Not Supported
Reverb Effect Not Supported
[ MPU-401 ]
Device Class Output Port
MIDI Channels 16
Synthesizer Type Software
Audio Channels 2
MIDI Channels 16000
Voices 1000
Available Memory System Memory
DLS L1 Sample Collections Supported
External MIDI Port No
Reverb Effect Supported
[ Bluetooth Audio ]
Audio Channels 2
MIDI Channels 16000
Voices 1000
[ Microsoft MIDI Mapper [Emulated] ]
Device Description Microsoft MIDI Mapper [Emulated]
Device Type Windows Multimedia
MIDI Channels 16
Port Sharing Supported
[ Microsoft GS Wavetable SW Synth [Emulated] ]
Device Description Microsoft GS Wavetable SW Synth [Emulated]
MIDI Channels 16
[ MPU-401 [Emulated] ]
Device Description MPU-401 [Emulated]
MIDI Channels 16
MIDI Channels 16
[ Microsoft Synthesizer ]
Device Description Microsoft Synthesizer
Device Type User-Mode Synthesizer
Audio Channels 2
MIDI Channels 16000
Voices 1000
DirectSound Supported
DLS L2 Sample Collections Supported
DirectX Input
[ Mouse ]
DirectInput Device Properties:
Device Description Mouse
Device Type Unknown
Device Subtype Unknown
Axes 3
Buttons/Keys 3
DirectInput Device Features:
Emulated Device Yes
Alias Device No
Polled Device No
Polled Data Format No
Attack Force Feedback Not Supported
Deadband Force Feedback Not Supported
Fade Force Feedback Not Supported
Saturation Force Feedback Not Supported
+/- Force Feedback Coefficients Not Supported
+/- Force Feedback Saturation Not Supported
[ Keyboard ]
Device Description Keyboard
Device Type Unknown
Buttons/Keys 128
Emulated Device Yes
Alias Device No
Polled Device No
Windows Devices
[ Devices ]
Computer:
Advanced Configuration and Power Interface (ACPI) PC 5.1.2600.0
Disk drives:
QUANTUM FIREBALL EX6.4A 5.1.2535.0
SAMSUNG SV4002H 5.1.2535.0
Display adapters:
NVIDIA GeForce FX 5200 7.8.0.1
DVD/CD-ROM drives:
ASUS CRW-2410A 5.1.2535.0
ASUS DVD-ROM E616 5.1.2535.0
Floppy disk controllers:
Standard floppy disk controller 5.1.2600.0
Floppy disk drives:
Floppy disk drive 5.1.2600.0
IDE ATA/ATAPI controllers:
Intel(R) 82801BA Ultra ATA Storage Controller - 244B 5.1.2600.2180
Primary IDE Channel 5.1.2600.2180
Secondary IDE Channel 5.1.2600.2180
IEEE 1394 Bus host controllers:
OHCI Compliant IEEE 1394 Host Controller 5.1.2535.0
Keyboards:
Standard 101/102-Key or Microsoft Natural PS/2 Keyboard 5.1.2600.2180
Mice and other pointing devices:
PS/2 Compatible Mouse 5.1.2600.0
Monitors:
Plug and Play Monitor 5.1.2001.0
Network adapters:
1394 Net Adapter 5.1.2535.0
Bluetooth LAN Access Server Driver 1.4.2.8
Bluetooth LAN Access Server Driver - Packet Scheduler Miniport 5.1.2535.0
Direct Parallel 5.1.2535.0
Realtek RTL8139 Family PCI Fast Ethernet NIC 5.398.613.2003
Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport
5.1.2535.0
WAN Miniport (IP) 5.1.2535.0
WAN Miniport (IP) - Packet Scheduler Miniport 5.1.2535.0
WAN Miniport (L2TP) 5.1.2535.0
WAN Miniport (PPPOE) 5.1.2535.0
WAN Miniport (PPTP) 5.1.2535.0
Non-Plug and Play Drivers:
1394 ARP Client Protocol
AFD
Beep
Bluetooth Port Client Driver
Bluetooth Protocol Stack
Bluetooth Serial Driver
dmboot
dmload
ElbyCDIO Driver
Fips
Generic Packet Classifier
HTTP
IP Network Address Translator
IPSEC driver
ksecdd
mnmdd
mountmgr
NDIS System Driver
NDIS Usermode I/O Protocol
NDProxy
NetBios over Tcpip
Null
PartMgr
ParVdm
RDPCDD
Remote Access Auto Connection Driver
Remote Access IP ARP Driver
Remote Access NDIS TAPI Driver
TCP/IP Protocol Driver
VET File and Macro Monitor
VET File System Filter
VET File System Recognizer
VgaSave
VolSnap
vsdatant
Windows Socket 2.0 Non-IFS Service Provider Support Environment
Ports (COM & LPT):
Bluetooth Communications Port (COM3) 1.4.2.8
Communications Port (COM1) 5.1.2600.0
Communications Port (COM2) 5.1.2600.0
ECP Printer Port (LPT1) 5.1.2600.0
Processors:
Intel(R) Pentium(R) 4 CPU 1.60GHz 5.1.2600.0
Sound, video and game controllers:
Audio Codecs 5.1.2535.0
Bluetooth Audio 1.4.2.8
Intel(r) 82801BA/BAM AC'97 Audio Controller 5.1.2535.0
Legacy Audio Drivers 5.1.2535.0
Legacy Video Capture Devices 5.1.2535.0
Media Control Devices 5.1.2535.0
Microsoft Kernel System Audio Device 5.1.2535.0
Microsoft Kernel Wave Audio Mixer 5.1.2535.0
Microsoft WINMM WDM Audio Compatibility Driver 5.1.2535.0
MPU-401 Compatible MIDI Device 5.1.2535.0
Standard Game Port 5.0.0.0
Video Codecs 5.1.2535.0
Storage volumes:
Generic volume 5.1.2600.0
System devices:
ACPI Fan 5.1.2600.2180
ACPI Fixed Feature Button 5.1.2600.2180
ACPI Power Button 5.1.2600.2180
ACPI Sleep Button 5.1.2600.2180
ACPI Thermal Zone 5.1.2600.2180
Direct memory access controller 5.1.2600.2180
Intel(R) 82801 PCI Bridge - 244E 5.1.2600.2180
Intel(R) 82801BA LPC Interface Controller - 2440 5.1.2600.2180
Intel(R) 82801BA/BAM SMBus Controller - 2443 5.1.2600.2180
Intel(R) 82845 Processor to AGP Controller - 1A31 5.1.2600.2180
Intel(R) 82845 Processor to I/O Controller - 1A30 5.1.2600.2180
ISAPNP Read Data Port 5.1.2600.2180
Logical Disk Manager 5.1.2600.2180
Microcode Update Device 5.1.2600.2180
Microsoft ACPI-Compliant System 5.1.2535.0
Microsoft System Management BIOS Driver 5.1.2600.2180
Motherboard resources 5.1.2600.2180
Numeric data processor 5.1.2600.2180
PCI bus 5.1.2600.2180
Plug and Play Software Device Enumerator 5.1.2600.2180
Printer Port Logical Interface 5.1.2600.2180
Programmable interrupt controller 5.1.2600.2180
System board 5.1.2600.2180
System CMOS/real time clock 5.1.2600.2180
System speaker 5.1.2600.2180
System timer 5.1.2600.2180
Terminal Server Device Redirector 5.1.2600.2180
Terminal Server Keyboard Driver 5.1.2600.2180
Terminal Server Mouse Driver 5.1.2600.2180
Volume Manager 5.1.2600.2180
Universal Serial Bus controllers:
Intel(R) 82801BA/BAM USB Universal Host Controller - 2442 5.1.2600.2180
Intel(R) 82801BA/BAM USB Universal Host Controller - 2444 5.1.2600.2180
USB Root Hub 5.1.2600.2180
[ Computer / Advanced Configuration and Power Interface (ACPI) PC ]
Device Properties:
Driver Description Advanced Configuration and Power Interface (ACPI) PC
INF File hal.inf
Hardware ID acpipic_up
[ Disk drives / QUANTUM FIREBALL EX6.4A ]
Device Properties:
INF File disk.inf
Hardware ID IDE\DiskQUANTUM_FIREBALL_EX6.4A_________________A0 A.0D00
[ Disk drives / SAMSUNG SV4002H ]
Device Properties:
INF File disk.inf
Hardware ID IDE\DiskSAMSUNG_SV4002H_________________________QP 200-05
[ Display adapters / NVIDIA GeForce FX 5200 ]
Device Properties:
Driver Description NVIDIA GeForce FX 5200
Driver Date 02-Aug-05
Driver Version 7.8.0.1
Driver Provider NVIDIA
INF File oem6.inf
Hardware ID PCI\VEN_10DE&DEV_0322&SUBSYS_13511682&REV_A1
PCI Device Pine Tech. GeForce FX 5200 Video Adapter
Device Resources:
IRQ 11
Memory 000A0000-000BFFFF
Memory D8000000-DFFF
hippi is offline
Old 04-01-2006, 09:46 PM   #2 (permalink)
one hellla long post but i think its the case of faulty RAM module... try to borrow ur frnds RAM module and then see if the problem still persists.
since u swapped the RAM mdoules, ur RAM socket may also be at fault... try to RUN windows with only one module at a time
Shwetanshu Srivastava
shwetanshu is offline
Old 04-01-2006, 09:53 PM   #3 (permalink)
my friend checked his RAM modules(he had two initially ) and found that one was corrupt ..so he changed that and bought new one..which he checked and it was perfect then also this problem is not solved..he started getting error screens after few weeks
i also checked both ones by running xp on single module and found both r working modules...
and BTW
SORRY for long post but i had to post my entire everest report and i donno which part to paste..so pasted entire thing..
if someone can tell me exact part to paste then i will edit my post removing unwanted thing...as i even remotely donno the problem area..
also is this problem heat related?
i am using my comp removing its cabinet cover ..but i am geting error messages...
P4 1.6Ghz,768MB SDRAM , on i845 mobo ,Philips 150S4 lcd on sis 315 Pro with 128MB VRAM ,40GB ATA100 5.4K rpm HDD,wifi enabled.hate sound card
hippi is offline
Old 05-01-2006, 12:14 AM   #4 (permalink)
RAM??? i dnt think that the RAM is at fault........ its something related to ur hard disk(remember that tuck sound???).......or may be your OS. u have mentioned that u just installed another copy of xp over the previous one........ try formatting ur drive and then reinstalling the OS(a clean install).......... that should solve your problem. make sure u do a complete format and not a quick format. and if possible format it via dos(not the windows xp cd).
satbir is offline
Old 05-01-2006, 02:28 AM   #5 (permalink)
yrana2002's Avatar
KERNAL_DATA_INPAGE_ERROR
Technical Information:
STOP: 0*0000007A( 0*C0384020, 0*C00000E, 0E1008820, 0*0AC18880)
This was what my pc used to give me frequently with those clicking noises and the next thing i knew was a changed new hard disk.
Its gotta be a problem with your hard disk.
Better back up your data as soon as possible
Do you get this error message?
Physical Memory Dump
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 05-01-2006, 07:43 AM   #6 (permalink)
Gracias Senor
dreams's Avatar
I donno wat causes these problems.. but due to some personal experience i can giv u some sugg..
First of all when blue screen haunts ur PC just format ur Windows Drive and fresh install Xp..
also i hv some prob caused with XP and SP2.. so it can also b the prob..
or else try installin any other OS like 2000 and try..
dreams is offline
Old 05-01-2006, 01:04 PM   #7 (permalink)
well...i get physical memory dump message but i think it is some kind of tool to debug donno how to use it..and btw dreams ..is it seriuosly problem with sp2 as i can remember my first installation of XP vannila was stable but cant recall after that...also installing fresh copy of XP on same partition as old one without formatting (ie. overwriting existing one)
can cuase problem?
of late now my zonealram also failed...and btw i bought new HDD MAXTOR 160GB ..but my old one does not have ne bad sector...so how to recognise that HDD is about to fail...?
hippi is offline
Old 05-01-2006, 07:52 PM   #8 (permalink)
yrana2002's Avatar
You could use HDD life which uses the S.M.A.R.T technology for monitoring your hard drives. If your performance goes below 35%, better be careful.
Not very reliable though.
