Old 04-01-2006, 07:52 PM   #1 (permalink)
Default Spider.sav ??
Hi,
i've this small problem
anytime i download something, spider.sav file also gets saved in the same folder.
Is that file harmful?
What is it exactly?
Pls tell me.
Radhika is offline
Old 04-01-2006, 08:53 PM   #2 (permalink)
siriusb's Avatar
If you play Spider Solitaire, then it's probably that game's save game file. If the file seems to be in more than one directory, then you probably have the Bugbear virus. Do a virus scan.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 04-01-2006, 09:49 PM   #3 (permalink)
mine is located in My documents folder
Shwetanshu Srivastava
shwetanshu is offline
Old 04-01-2006, 10:15 PM   #4 (permalink)
siriusb's Avatar
'My Document' is the spider's home
If you see a spider anywhere else, swat it, for it's a virus pretending as a spider. Also, the virus one has the extension spider.sav.exe or .scr
siriusb is offline
Old 06-01-2006, 01:50 AM   #5 (permalink)
piyush gupta's Avatar
my comp has spider.sav in My dicouments do it is a problem or some worm or trojan ??
piyush gupta is offline
Old 06-01-2006, 02:59 PM   #6 (permalink)
the_moon's Avatar
Virus?!
I play spider Solitaire & wenever i save my game the file gets stored in the same folder, where the game's shortcut is. Is that A Virus?!???!
the_moon is offline
Old 06-01-2006, 03:51 PM   #7 (permalink)
siriusb's Avatar
Let me say it again, Spider.sav in 'my documents' is harmless. If u find the file elsewhere with an executable extension like spider.sav.exe, then it is a virus infection.
siriusb is offline
