Old 03-01-2006, 11:47 PM   #1 (permalink)
Default Yahoo! Messenger has encountered a problem help!!
Yahoo! Messenger has encountered a problem and needs to close. We are sorry for the inconvenience.
how to solve this problem
NagpurDaMunda is offline
Old 04-01-2006, 12:03 AM   #2 (permalink)
__Virus__'s Avatar
1) Make sure you are not being booted. Sign in invi mode and check just for isolation.
2) Unistall yahoo. Clear ur system of all yahoo files. Clean registry with good registry cleaner.
3) Update windows if not done.
4) Download and install fresh copy of yahoo ( dont go for betas they suk)
__Virus__ is offline
Old 04-01-2006, 12:14 AM   #3 (permalink)
Reply :-
i cant go for 1st option as my messenger is not getting started
i cant go for 3rd option coz i installed fresh copy of windows yesterday only
i cant do 2 and 4 th option as i had downloaded n installed it today only n also it was working fine but started giving problems just now
Old 04-01-2006, 12:36 AM   #4 (permalink)
what version of windows do u have? and what version of yahoo did u download? if u hav not updated windows to sp2 and also not hav installed latest security updates, i am pretty sure that is the problem...
/legolas
legolas is offline
Old 04-01-2006, 01:06 AM   #5 (permalink)
invisible
Posts: n/a
/legolas
You might b right.
Make sure that u have installed SP2 and ZoneAlarm AV+FW before connecting to the net.
I cant think of any other problem.
Old 04-01-2006, 01:29 AM   #6 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
Check for WinParite infection.
I had been facing the same problem for a long time until a virus scan threw up Parite 32 infection. After getting rid of it, I could get Y! Messenger up and running.
Also see if you are using any Windows Skin programs like Windows Blind etc. Try to disable them and get back to default XP mode and see if it works.
The ANGRY Pixel proudly announces the launch of India's first ever launch center for a game, The ANGRY Pixel - Milestone Interactive Street Fighter 4 Launch Center
ctrl_alt_del is offline
Old 04-01-2006, 03:29 PM   #7 (permalink)
See if it works, it worked for me. Install a copy of Macromedia Flash Player SA and Shockwave too. I got the same error no matter how many time I install and reinstall. Try it..
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 04-01-2006, 08:41 PM   #8 (permalink)
yahooooooooooooooooooooooooooooooooooooooooooooooo ooooooo thank u very much krish it worked for me after installing flash player
Old 04-01-2006, 09:45 PM   #9 (permalink)
Default Hmm.. Weird...
I have never faced any problems with Yahoo! Betas including the latest 7.5! it works like a charm anyway glad to know NagpurDaMunda's problem is solved
PavanPoghul is offline
Old 05-01-2006, 09:58 AM   #10 (permalink)
Thanks NagpurDaMunda and __Virus__ for your comments
krish is offline
- by Krow
