Old 03-01-2006, 11:05 PM   #1 (permalink)
Default connecting TV with computer using agp card
my system config. is as following
Intel D850 MV motherboard
Intel PIV 1.7ghz 256kb L2 cache
768 MB RD Ram (400 MHZ)
Radeon 9200 SE AGP 128 MB
now my problem is that whenever i connect my tv to the agp through
s-video cable then the tv display is black and white
what must be the problem???
i had tried on low resolution but it doesn't help me
i m using Windows XP Professional sp1
thadhanihemant is offline
Old 04-01-2006, 12:52 AM   #2 (permalink)
choudang's Avatar
same problem with nVidia GeForce 5200 AGP 128 MB.... anybody is there to help us
For every action, there is an equal and opposite criticism.
choudang is offline
Old 04-01-2006, 08:59 AM   #3 (permalink)
Hi...there could b 2-3 probs
one is that mebe the agp output is in NTSC and ur TV is PAL or vice versa
another is that sometimes using diff kinds of cables helps, like it mite be b/w in svideo to dvideo, but could b colour in svideo to composite
see this site i found stuff here - http://www.realtimesoft.com/multimon...&tmpl=UltraMon
ishaan is offline
Old 04-01-2006, 03:01 PM   #4 (permalink)
Works perfectly for me with FX 5200
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 11-01-2006, 12:15 AM   #5 (permalink)
well ishaan thanks for the reply
i updated my drivers and set the tv display to ntsc, and finally removed the ati catalyst control centre
and this time it worked perfectly for me
thanks
Old 11-01-2006, 12:24 AM   #6 (permalink)
this should solve the problem , in most cases
Techie_Geek is offline
Old 11-01-2006, 12:26 PM   #7 (permalink)
choudang's Avatar
can you give me a details, how did you do this.... i'm using 81.98 forceware driver [tats the latest one] and using a THOMSON tv...... when i tried... TV gives me a hazzy black screen.....
if you give me the proc.. thats help me out
choudang is offline
Old 11-01-2006, 01:44 PM   #8 (permalink)
warrior, I just connected my TV (Videocon 24 carat) to the system thru the s-cable and switched on the system. Initially it was not clear but when I lowered the resolution, it worked perfectly (though the picture is not as clear as on monitor).
Well, I had to adjust the system to PAL/NTSC to view it in colour. Try changing it the setting.
krish is offline
Old 11-01-2006, 01:46 PM   #9 (permalink)
ur welcome
ishaan is offline
Old 11-01-2006, 03:07 PM   #10 (permalink)
as krish said .. its not the cable
its the system
for india set it to "PAL-B" and everything should work fine. ..
No Mercy, No Limits.
theraven is offline
- by Krow
