Old 03-01-2006, 08:34 PM   #1 (permalink)
Default Problem with RAM
i have a Intel 845 GB motherboard.
i would like to know if i can insert an 512 MB 400mhz RAM with my 128 MB 266mhz RAM.
nitinjavakid is offline
Old 03-01-2006, 08:40 PM   #2 (permalink)
dIgItaL_BrAt's Avatar
Yes u can,but there is a chance that the chips might be incompatible.If they are compatible,it will run perfectly but be aware that the 512 MB/400 Mhz chip will underclock and run at 266 Mhz.
dIgItaL_BrAt is offline
Old 03-01-2006, 10:16 PM   #3 (permalink)
::cyborg::'s Avatar
u will have frquent restarts as it happened to me if u hv the 266 mhz mobo then u should try 266mhz ram
::cyborg:: is offline
Old 04-01-2006, 12:44 AM   #4 (permalink)
ymhatre's Avatar
Default Rambling
I have intel 845 Gb, P4 2.4ghz having 128mb ram (266 fsb).
I am planning to buy 512 mb ram.
Will 512 mb of 400 fsb will work on my board along with 128mb which is at 266 fsb.
or only 512 of 266 will work with 128 of 266 fsb.
PLz any one answer this
ymhatre is offline
Old 04-01-2006, 12:57 AM   #5 (permalink)
choudang's Avatar
sorry......... your mobo should have the support for 400Mhz RAM.... if u have.... u can but u will face some BOSD and restarts
For every action, there is an equal and opposite criticism.
choudang is offline
Old 04-01-2006, 01:09 AM   #6 (permalink)
invisible
Posts: n/a
EDIT: sorry......... your mobo should have the support for 400Mhz RAM.... if u have.... u can but u may face some BOSD and restarts
Old 04-01-2006, 08:17 AM   #7 (permalink)
Even mobo's having no support for 400 Mhz chips will support it,but at 266 Mhz only.
Old 04-01-2006, 09:42 AM   #8 (permalink)
this will require to update ur bios with ur mobo bios patch if it allow to attach than only take risk to attach otherwise it will work bot after some time it start togive error of pagefault and many more
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
Old 04-01-2006, 10:20 AM   #9 (permalink)
huh?? i have been using two kingston 512 MB modules @ 400Mhz on my 845 GL mobo for over 1 and a half yr, i nvr got such error.
Shwetanshu Srivastava
shwetanshu is offline
Old 04-01-2006, 08:03 PM   #10 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
same topic goin on here
http://www.thinkdigit.com/forum/view...361&highlight=
vijay_7287 is offline
Old 04-01-2006, 08:51 PM   #11 (permalink)
ymhatre's Avatar
Originally Posted by vijay_7287
can u please letme know the cost of 512 (266) Hynix ram
also specify which make / brand /manufacturer is good in buyying it
if possible plz tell where would i get it on these plannet (i mean specify address of the shop in mumbai)
ymhatre is offline
- by Krow
