Schedule Your Pc to turn on Automatically
I will tell how to scheduele Your PC to turn on automatically at 2:00 AM and shutdown at 8:00 AM for
DataOne users.
I Will give two methods.
1. Using "Auto Power-on and shutdown" software (Very easy)
2. Manually configuring using Scheduled Task
1. Download and install the free 30 days trial of "Auto Power-on and shutdown" from
here .Restart pc if required.
2.Now in the Power on TAB select everyday for Power on date.
3.Next enable power on time and set the time to H:02 M:00 S:00 i.e., 2:00 AM
4.Enable shutdown time and set it to H:08 M:00 S:00 i.e., 8:00 AM
5.Click OK (Important)
6.Now you will get a dialogbox asking to select a setupmode for power on. Select "Setup automatically"
and click next
7.In the next dialog select "Test now" and click OK. Now the system will hybernate, and will turn on
automatically after a minute. Select OK in the next dialog box.
Thats all you are done.
Method 2 comming up Please be patient
Thanks Charan
