yes
most probably ur gfx card will hav either a composite video out, or an svideo out, or both
whicchever u wanna use, get it's wire wich is very easily available at tv repair shops, electronics shops, computer shops, etc....and they very cheap also
then jus connect ur gfx card 2 ur pc and use ur gfx card software to put the display on ur tv
why didnt see u the post just made a lil wile ago?
http://www.thinkdigit.com/forum/viewtopic.php?t=35217
