02-01-2006, 01:15 AM
dvd regions
hii jus got loads of DVDs from diff countries n i tried using them on my laptop but ive already changed the region number of my drive 5 times so im stuck on region 3 whereas these DVDs need other regions
i tried 2 use DVDRegion Free but it didnt work prperly only audio came no video
does ne1 no ne way i can see those DVDs on my laptop?
02-01-2006, 01:37 AM
i think DVDfab helps in viewing it immaterial of the region.. not quite sure thou. check it out.
/legolas
02-01-2006, 09:00 AM
left this forum longback
In Linux distributions using DVDCSS,region decryption doesnt arise..just play.. 8)
libdvdcss
libdvdcss is a simple library designed for accessing DVDs like a block device without having to bother about the decryption.
Features
* Portability. Currently supported platforms are GNU/Linux, FreeBSD, NetBSD, OpenBSD, BSD/OS, BeOS, Windows 95/98, Windows NT/2000, MacOS X, Solaris, and HP-UX.
* Simplicity. There are currently 7 functions in the API, and we intend to keep this number low.
* Freedom. libdvdcss is released under the General Public License, ensuring it will stay free, and used only for free software products.
* Just better. Unlike most similar projects, libdvdcss doesn't require the region of your drive to be set.
http://developers.videolan.org/libdvdcss/
02-01-2006, 09:05 AM
In Pursuit of "Happyness"
Use AnyDVD from http://www.slysoft.com Same ppl who make clone cd
02-01-2006, 09:06 AM
02-01-2006, 09:19 AM
hi thx....dvdFAB have jus made a software called DVDFAB DECRYPTER...wich ri[s the movie first to make it region free...thats like almost all dvd rippers so i didnt want that
kalpik and dIgItaL_BrAt - thanks it worked!
02-01-2006, 01:48 PM
hmm it worked in the morning but now i tried diff DVDs of diff regions n its not working...it turns out its only working when the dvd region needed is 1 and my drive is stuck on 3
i tried a dvd needing region 2, and one needing 5 and it didnt work
ne other softwares?
ps-my dvd drives are MATSH ITA UJ-822Da and an external FREECOM FX-50
deres no space in MATSH ITA but i gotta put it cuz d forums recognize 'sh|t' and censor it lol
03-01-2006, 12:34 AM
Isnt it illegal to change the region codes more than 5 times?I dont think this topic must be discussed.
03-01-2006, 03:19 AM
before the topic locks up jus wanna say,there is something called firmware from some sources(use @ ur own risk!)  which can make supprted dvd drives reg**n free!
03-01-2006, 06:41 AM
AnyDVD does not change the region code,it just fools the OS into thinking that that the DVD inserted has the proper region code.Also it's perfectly legal.
03-01-2006, 10:27 AM
yeah its not illegal...but i think it doesnt support my drives...even dvd regionfree...sigh
03-01-2006, 10:29 AM
Hmm... Thats really odd.. AnyDVD works just fine on all drives i installed it on..
03-01-2006, 10:32 AM
i tried it on my other computers it worked perfect, but not with this one so i gez that must b d prob
03-01-2006, 10:40 AM
Actually AnyDVD does not depend on the type or make of drive!! Its just a windows driver!! So i doubt your drive is the problem!
AnyDVD works in the background to automatically remove the copy protection of a DVD movie as soon as it's inserted into the drive, allowing you then to backup the movie using a DVD backup tool such as CloneDVD. You can also remove the RPC region code, thereby making the movie region free and viewable on any DVD player and with any DVD player software.
AnyDVD is capable of removing unwanted movie features, including subtitles and prohibition messages such as copyright and FBI warnings. It also allows you to launch an external application whenever you insert or remove a disc, or prevent 'PC-friendly' software from automatically launching when you insert a video DVD.
Decryption is not all that AnyDVD offers. You can control the drive speed of your DVD drive, allowing you to reduce the noise level when watching movies on your PC. You can even adjust the display frequency of your monitor for both NTSC and PAL displays.
But AnyDVD doesn't just stop at DVDs. It also decrypts protected audio CDs to allow you to copy them.
Features
* Works automatically in the background
* Removes encryption (CSS) and region code (RPC) from DVDs
* Removes analogue copy protection (Macrovision)
* Removes features such as forced subtitles and warnings
* Decrypts without the need to save the data onto your hard-disk
* Decrypts 'on the fly'
* Prevents automatic launching of 'PC-friendly' software on video DVDs
* Allows adjustment of your monitor refresh rate for both NTSC and PAL monitors
* Allows execution of external programs on disc insertion and removal
* Allows speed control of your DVD drives
* Compatible with all DVD media
* Works with all DVD-drives, regardless of region code
* Works with all DVD copying, such as CloneDVD, and all DVD player software
* Works transparently for the operating system: DVDs can be shared over the network and copied with the command prompt or with Windows Explorer, etc.
* Proven to be stable and fast and does not require an ASPI driver
* Features AnyCDDA: play, copy and rip protected audio CDs
03-01-2006, 11:25 AM
@ishaan:try changing the default region in the AnyDVD options,to the region of the disc u are using.
03-01-2006, 01:14 PM
try this one before deciding on prbs with DVD drive...
link
/legolas
Search this Thread |
