Old 20-10-2004, 10:33 AM   #1 (permalink)
Laptoping
Sourabh's Avatar
Default Whts the life of a average cd writer???
btw guys just wanted yo knw is there any particulat lifetime of a cd writer in terms of how many cds it can write or in time duration??
i have screwed 2 cd writers till now
n the third liteon one is almost dead giving errors in burnt discs
y is it so??
i burn abt 6-8 cds everyday but sometimes even more than tht
averagely i burn abt 200cds in a month is this the reason y my cd writers get screwed up??
i have a 350W SMPS power supply (not sure whether this may b the reason for tht too )
Do the cd-writing softwares one uses have a efect on this??
also does less system resources while burnng cds have effect on cd-writers?
Sourabh is offline
Old 20-10-2004, 05:00 PM   #2 (permalink)
I do not burn much CD's so mine has given me good results for 1 1/2 yrs now
Walk on the Wild Side. The other side SUX!!!
krazydude is offline
Old 20-10-2004, 05:19 PM   #3 (permalink)
Laptoping
Sourabh's Avatar
Default whts the prob
y does my writer get scrwed up so early
is burning this much cds harmful for the writer coz this i feel this is s**t.
its like your pc wod get scrwed if u use it much or ur gfx card wod blow if u play more games
Sourabh is offline
Old 20-10-2004, 09:48 PM   #4 (permalink)
sunnydiv
Posts: n/a
yeh i dont think that can be it, or esle they would mention like they do with lcd, and plasma, this much hr , so and so
dexter shead light
Old 21-10-2004, 12:31 AM   #5 (permalink)
well i too had the same issues with my cd writer when i was to deep into the CD piracy business ~ , the solution ? I used to change the cd drives twice a YR , and i always used to go for cheap cd writer's from LG or Samsung , cause buying liteon / HP didnt make any sense.Well nothing more into it , Really !
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
indro is offline
Old 21-10-2004, 09:54 AM   #6 (permalink)
actually the average life of a cd writer depends on many factors.Which include the usage the power conditions the quality and handling.Most of us do not clean our writers.i dont mean cleaning it by opening the writer.i mean by using a cd lens cleanerWe should also meke sure that we do not overheat the write by writing too many cd too fast.Give the poor thing a break.
seetendra is offline
Old 22-10-2004, 03:45 AM   #7 (permalink)
Having used CD writers for a few decades, It lasts 1000-2500 writes. I still got a over 20 year old 1x scsi writer that worked the last time I checked. As you can imagine, that drive does not have 1000 writes on it My liteon 24x conked out and would not recognize disks after 3 years but I had almost 2000 writes on it. Some others with 500 or so writes lasted 2-3 years as well. So it depends.. Dirt would be the thing that seems to destroy the drive. Although a ricoh one I had would not write the last 20% of a disk after just like 100 disks but it still works other wise. So if you are lucky and careful 5 years should be it or 2000 cd's which ever comes first.
ps.. this is not in india.. I would cut the life of a drive by less than 1/2 here. Maybe 1/4 in many cases unless you get real good UPS/power supplies etc. My wife already burnt out 2 computers that I had used for years with no problems and never seen so many problems crop up with stuff. Think even with UPS and such, things are made so cheapely that spilkes and such get through no matter what you do.
AlienTech is offline
Old 22-10-2004, 08:05 AM   #8 (permalink)
Let the music play.....
djmykey's Avatar
mmmm I got a lg writer which is alive with me for almost 4 3/4 years man thats a long time na. Yes thats because i bought it for 12,000 and its only 8x and yes i hardly use it i burn almost hardly 100 cds a month. Sourabh i dunno but still i think this maybe the solution my sir durin a lecture told me that maintaining a cdrom or rw means cleaning it with a cd rom lens cleaner everyday !! every 1 was puzzled to this statement of his but he was cool and sai what wud u do if u had to keep a glass surface clean, u wud wipe it every day right the same thing applies here. check that thing out and tell me if it helped and yes u burn lotsa cds so try to keep it low or keep some delay between 2 cds and also keep the drive door open after writing a cd for sometime this helps the heat to escape
djmykey is offline
Old 22-10-2004, 08:21 PM   #9 (permalink)
Well my friend was using a HP CD writer( Not available now)
he has burnt more than 700 CDs on it n the media he was
using was also not very good. His cd writer is still working
but prefer to use a good media(sony,samsung,moser bair etc)
to increase the life of ur cd writer.
It\'s a truism that our worst affected wounds are self inflicted
Just Another F*$%/ed up day in Paradise
SHell is offline
Old 23-10-2004, 09:40 PM   #10 (permalink)
FWIW, I assembled a 1:7 CD copier 18 months ago for a local cable TV company and they write 50-100 CDs every single day - that's about 7-14 CDs per drive per day. I used Liteon 52x writers and not a single one has failed so far. The quality of blanks has a lot to do with how many tea coasters you produce.
pimpom is offline
Old 26-10-2004, 03:01 PM   #11 (permalink)
rakee's Avatar
hey mine is an LG cd writer 3 years old..might have written nearly 500 cds..still as good as a new drive
The WaNNaB GeeK iNHOUSe
rakee is offline
Old 26-10-2004, 09:06 PM   #12 (permalink)
Laptoping
Sourabh's Avatar
Default ??
i still havent figured out y my cd-writers die so early !!
Sourabh is offline
Old 27-10-2004, 10:16 AM   #13 (permalink)
Many Factors
1. Quality of Media U use may not be good.
2. Lot of Dust in the surroundings
3. Bad Powersupply.
4. Are u friggin crazy or a Piracy master to burn 6-7 CD's Daily?
5. User too dumb(Not really a factor, Im just kidding )
6. Laser has a life, so since u r writing soo much , the laser's life span must be over..
Ok, Hope this answers ur query....
\"Hating people is like burning down your own house to get rid of a rat\" - Harry Emerson Fosdick
\"A Pessimist is one who makes difficulties of his oppertunities; an optimist is one who makes oppertunities of his difficulties\" - Reginald B. Mansell
oh yeah.. my Fav Quote
\"Sometimes a winner is just a dreamer who never gave up.\"
allajunaki is offline
Old 27-10-2004, 06:36 PM   #14 (permalink)
Bewitched!
xenkatesh's Avatar
Yeah mainting cdwriter gives good result!
1.good power supply...
2.good cds..
3.good cleaning(cd lens cleaner)....
4.good mintanence....
Try this Dude!!!!..............
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
- by Krow
