Old 31-12-2005, 09:48 AM   #1 (permalink)
Generic Superhero's Avatar
Default is formatting HDD bad?
is it true that formatting degrades hard disk performance?
Nipon
Generic Superhero is offline
Old 31-12-2005, 10:13 AM   #2 (permalink)
siriusb's Avatar
Frequent low-level formatting may be bad, but high level formatting is nothing special, afaik. Or is there a case against it?
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 31-12-2005, 10:15 AM   #3 (permalink)
a quick format isnt bad. it jus removes the references to local files. a zero-fill format(full format) intends to overload the hardisk and for that reason it is not to be done unless its of absolute necessity. thats y it may be of potential harm to ur hardisk. other than that there shud be no technical reason.
/legolas
legolas is offline
Old 31-12-2005, 10:16 AM   #4 (permalink)
hi-level and low-level format... wat are these?
Nipon
Old 31-12-2005, 10:34 AM   #5 (permalink)
he means low-level as zero-fill or full format and high-level as quick format. may be he means the level of abstraction as high and low. low level means u get deeper inside by formatting everything...
/legolas
legolas is offline
Old 31-12-2005, 02:11 PM   #6 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
I really doubt if thats the case. For one i have myself formatted my harddrive atleast 30 times in the past year.
Secondly I read some time ago that some users do a format of the system every 2 months just to keep things clean.
Lastly an occasional format (once in a year) is hardly somethng to be bothered about.
Just do a quick(or fast) format, it wouldn't hurt.
chesss is offline
Old 31-12-2005, 03:00 PM   #7 (permalink)
well with windows OS, we definitely hav to format within 2 months definitely and reinstall a fresh copy! thats known case.. thks to the "quick format"!!!
/legolas
legolas is offline
Old 31-12-2005, 05:31 PM   #8 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
in 2005 i formatted my disk i.e. some partitions more than 100 times i.e. quick format
no probs watsoever
vijay_7287 is offline
Old 31-12-2005, 07:52 PM   #9 (permalink)
Developer
koshyjohn's Avatar
Default HDD
Quick formatting justs clears the file allocation table (FAT) or the Master File Table (MFT on NTFS) which contain the references to files ie. the location of a file on the HDD and other properties like System, Read-only, Hidden, and possibly other meta-information.
Low level formatting reads and writes to each and every bit on your hard-disk, checking for bad sectors. This is very slow but can increase reliability when done occasionally on old HDDs.
koshyjohn is offline
Old 01-01-2006, 11:38 AM   #10 (permalink)
JGuru's Avatar
Formatting your Harddisk won't harm it.
I format every 2 months. Doing it for the past 5 years!!
Make sure you use a Good UPS like APC or Numeric.
Earth the Power supply properly.
That will do, Dude!!
JGuru is offline
Old 01-01-2006, 12:27 PM   #11 (permalink)
All this about formatting the HDD is fine....
But can anyone tell me whether formatting a flash disk is safe? I have a 1 GB stick & hav formatted it a couple of times...both quick format & full format....
I also remember having read a thread on this forum by some guy who formatted his flash stick & some space on it got corrupted & was rendered useless....Does this kind of a thing really happen?
Looking for answres...
HK
h_kunte is offline
Old 03-01-2006, 11:36 AM   #12 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
has anybody a link abt how 2 format HDD (new or old 1) ???
PS : 4 a newbie like myself ... i just hate 2 call my hdw vendor 4 such small things & get charged heavy ... help me plz ...
... W H O T ...
ax3 is offline
Old 03-01-2006, 12:03 PM   #13 (permalink)
Commander in Chief
QwertyManiac's Avatar
A windows user not knowin how to format ? Its like living w/o breatin ...
Enter DOS by typin "Cmd" in Start > Run.
Type ---> Format x: where "X" is ur partition alphabet which u wanna format.
Another workaround :
Right Click My Comp > Manage > Storage > Right click the partition u need to format/delete and choose te respective option.
To erase the whole windows, boot from a DOS disk, and type that "Format" command.
For more params, type format /? in dos/cmd
Harsh J
www.harshj.com
QwertyManiac is offline
Old 04-01-2006, 02:07 PM   #14 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
If u r a newbie i think u should not format hdd....
Quiz_Master is offline
Old 04-01-2006, 03:07 PM   #15 (permalink)
Hey guys...
I am still looking for answers to my earlier post in this thread.....
TiA
h_kunte is offline
Old 04-01-2006, 06:53 PM   #16 (permalink)
dIgItaL_BrAt's Avatar
My flash drive's working fine,and i've probably formatted it over a hundred times.
dIgItaL_BrAt is offline
- by Krow
