Old 30-12-2005, 07:28 PM   #1 (permalink)
hpotter606's Avatar
Default How to convert Xvid to VCD ?
Hi friends
I have got a video in Xvid format. I want convert it into mpeg or directly write on vcd(which is easier?). Which is the best tool for that? I searched google but did not find any good one.
Will the quality of video decreased due to convertion?
hpotter606 is offline
Old 30-12-2005, 08:02 PM   #2 (permalink)
u shud have searched here!
link1
link2
link3
/legolas
legolas is offline
Old 30-12-2005, 08:33 PM   #3 (permalink)
hpotter606's Avatar
I searched here!!
But i could not get the answer i thing i want.
I am trying every tutorial/guide you all mention in all those threads. Still if anyone has a direct answer to my questions please post it.
Old 02-01-2006, 06:12 PM   #4 (permalink)
hpotter606's Avatar
I converted the file from xvid format to mpeg. But there is a little problem.
1. Its Doesnt have sound!!!!
2. The mpeg file is of 3800 MB !!!!
3. The movie has only black screen( i.e. nothing) after completion of the movie. That makes it 3800 mb.
The orignal file is of 730 MB. I used TMPEGnc and followed the steps given in one of the tutorials.
What do i do now?
Old 03-01-2006, 07:15 AM   #5 (permalink)
Gracias Senor
dreams's Avatar
u can goto www.videohelp.com.
Thr r many solutions for ur query.
dreams is offline
Old 03-01-2006, 05:03 PM   #6 (permalink)
hpotter606's Avatar
I am talking about tutorials from videohelp itself!!!
Old 03-01-2006, 05:32 PM   #7 (permalink)
There are several things. First you need to know if the xViD contains an AC3 codec for the audio. AC3 is the 5.1 channel audio. If it does contain AC3 then you would need to extract the audio first as a wav file and then use that audio file in Tmpeg. You can extract the wav file using virtualdub. Why dont u save urself all the trouble and just use Nero Vision express It will do the complete job for you. Make sure you have the necessary plugins for Nero tho.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 05-01-2006, 09:09 AM   #8 (permalink)
hpotter606's Avatar
Will it be a good quality of the video?
Old 05-01-2006, 11:40 AM   #9 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Use virtualDub to split the file and then convert to mpg with the TMPEGnc. This also happened to me. When I tried to convert the whole file the result went to around 3000-4000MB. So simpy split the file. For more information on splitting avi see this: http://nickyguides.digital-digest.co...-split-avi.htm
john_the_ultimate is offline
Old 05-01-2006, 02:21 PM   #10 (permalink)
i think doom9.net mite also help
ishaan is offline
Old 10-01-2006, 04:24 PM   #11 (permalink)
hpotter606's Avatar
Thanks for your help guys!
I have splitted the video in 2 parts. Maybe it will work now.
Old 10-01-2006, 05:53 PM   #12 (permalink)
bala4digit's Avatar
i have xvid which does not show the video wat cud be the problem....it just plays audio !???
\"I\'ve Got A Great Ambition To Die Of Exhaustion Rather Than Boredom.\"
\"Where Would You Go When You Can\'t Forget The Past And You Don\'t Know The Future.\"
bala4digit is offline
Old 11-01-2006, 12:33 AM   #13 (permalink)
Default Re: How to convert Xvid to VCD ?
Originally Posted by hpotter606
Hi friends
just convet to avi using Dr.DivX and write them on CD.
Alternatively the compressed and encoded file can be written on a VCD using Nero 7, by the way r these the GOF movie discs!
Techie_Geek is offline
Old 11-01-2006, 02:12 PM   #14 (permalink)
AVI2DVD is for you!
You may do the task with or without splitting the file!
Download AVI2DVD here
www.trustfm.net/divx/SoftwareAvi2Dvd.html
Install.
launch & choose AVI mode.
nextly select output format and all that!
Add job & wait till its over!
If you want detailed help tell me! I will guide you!
upendra_gp is offline
Old 20-01-2006, 03:03 PM   #15 (permalink)
hpotter606's Avatar
Hi friends
Sorry, NO GOF movies.
BTW i said videos not movies
- by Krow
