Old 29-12-2005, 06:37 PM   #1 (permalink)
Pharmaguru
kjuvale's Avatar
Default Problem with IE6
i am having problem with internet explorer.
i am using bsnl bb 256kb
it give very fast speed with opera, firefox (pages open quickly)
but in intenet explore pages take very long time (slower than dialup) while some pages dont even open.
what can be the problem.
i have checked the firewall . also tried by turning it off.
please give solution as i am not able to see my usage records as the bsnl dataone only opens in iE and even if it opens in opera , i am not able to use bandwidth calculator by shaplus as it works only for ie
I am using windows xp professional sp2
My Photography gadgets :
Nikon D5100 with 18-55mm VR Lens, Nikkor AF-S 50mm 1.8g, Tamron VS 70-300 VC Di
Cullmann NANOMAX 220 Tripod. | Crumpler messenger boy stripes 4000 camera bag :grin:
kjuvale is offline
Old 29-12-2005, 07:51 PM   #2 (permalink)
did u install the security updates for ie? what ver. of ie are u having? are u facing this problem for a long time? or after u installed some particular softwares/updates etc.. u remember? post ur hijack this also.. wat ver. of ie do u use? checked for spywares? ie is very susceptible as far as i know.. provide with these and more possible details to get u the solution possibly!
/legolas
legolas is offline
Old 30-12-2005, 12:04 AM   #3 (permalink)
if u use IE only cuz of compatibility issues wid some sites, u can get this extension for firefox called IE Tab wich lets u open stuff in firefox as a tab behaving like IE
also see if ur speeds r slo on dat tab or not
ishaan is offline
Old 30-12-2005, 01:04 AM   #4 (permalink)
harsh bajpai
Posts: n/a
that's why firefox and opera exist. i seldom have problems opening sites with firefox 1.5 rather, once ever, and that too i think was that sites server prob.!
Old 30-12-2005, 05:49 AM   #5 (permalink)
Pharmaguru
kjuvale's Avatar
yes i am already using the ie tabs and it was working few days back but as it opens pages using ie in firefox same problem . but pages opened without ie tabs get opened quickly.
kjuvale is offline
Old 30-12-2005, 10:16 AM   #6 (permalink)
try reinstalling IE...and make sure it is fully updated..
as legolas said, do spyware scans on ur pc cuz i hav noticed spyware does affect IE more than other browsers, cuz most ppl use IE so the makers of the spyware use IE exploits more often
ishaan is offline
- by Krow
