Old 29-12-2005, 01:46 PM   #1 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default NTFS to FAT32 problems
Due to some problems in my system I wanted to format the hard disk. But then I realized that it is NTFS System. I had to take precautions while formattting the system and reinstalling everything on it. I tried to convert into FAT32 using Partition Magic 8.05 but it halted because of too many errors and that too even after uncompressing all the files on NTFS Volume.
Now I want to ask can I use this procedure to reinstall Windows XP
1. Boot using Windows 98 Floppy Disk
2. Windows Setup Files(copied from Orginial CD) are on FFAT32)
3. Install Windows XP to C:\ by formatting C:\ to NTFS again from there.
Will this method work b'coz i don't want FAT32 but want fresh clean install of Windows XP?
navjotjsingh is offline
Old 29-12-2005, 02:05 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
YES! U can......
First boot using 98 bootable floppy disk and goto the drive, where u hv dumped windows XP setup (Drive letter will be changed from F: to other bcoz 98 will not recognise the ntfs partitions)
Now goto the XP setup folder "i386" and then type "winnt.exe".
It'll start XP setup and then u can select the partition, on which u want to install fresh XP
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 29-12-2005, 05:54 PM   #3 (permalink)
__Virus__'s Avatar
Works great as visual said. Directly booting with windows xp CD and selecting partition to install and then selecting appropriate option of partition type will me more easy
__Virus__ is offline
Old 29-12-2005, 08:39 PM   #4 (permalink)
I am Optimus Prime
The method I mentioned does not work b'coz I used Win XP files on HDD and under floppy all setup files got copied to dFAT32 - Unbootable Non Active Partition) and my system is still as it is.
I will now use Windows XP bootable CD tommorow and check.
- by Krow
