Old 28-12-2005, 09:59 PM   #1 (permalink)
tuXian's Avatar
Default Branded File Extensions On Web Server
DirectI is launching web hosting services to its resellers come Jan 1 2006.
I was just checking the demo of their hosting service and found an option called Branded File Extensions. Since its a demo I couldnt implemented.
From the interface [See Screenshot below] I could see an option to create an extension say .dig (short for digit) and then assign a regular content type like txt/html. Thus www.thinkdigit.com/index.dig will take the user to www.thinkdigit.com/index.htm
I would like to know from the web experts here is that possible in any server by some means. If yes please throw some light as it would be of great help.
tuXian is offline
Old 28-12-2005, 10:17 PM   #2 (permalink)
Version 2.0
Deep's Avatar
Yes its very easy basically...all you need to do is make a MIME type of whatever ext. u want and thats it..
If you are using CPANEL then click on Icon called MIME Types
then now in first box - Mime Type - put the MIME type you want....
for example..if you want ext of PHP pages as say .tux
then put this in left box
application/x-httpd-php
and in right box put tux
and click on add
Or you can do this manually by editing httpd.conf too...
Regards,
Deep
Deep is offline
Old 28-12-2005, 10:22 PM   #3 (permalink)
tuXian's Avatar
Cool.... thanks a zillion Deep
Like always you reply with great pro finesse and ease.
You know it's love when you memorize her IP to skip DNS overhead.
tuXian is offline
Old 28-12-2005, 10:24 PM   #4 (permalink)
Version 2.0
Deep's Avatar
Always welcome sir
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
- by Krow
