Old 19-10-2004, 01:03 PM   #1 (permalink)
Default Computer restarts frequently?
Hello Sir,
I am Sandeep Sharma a website designer working in Jaipur, INDIA. I recently purchased an Intel 2.4 GHZ P4 HT with Intel Desktop Board D865GBF . From past 5 days I am facing a strange problem. My system display is not working properly. Whenever I start playing games like Serious Sam the game runs 4 to 5 minutes perfectly and then the computer restarts automatically but this problem is not face by me in any other computer. Is it a hardware problem or a software problem? Please help me.
Thank you,
Sandeep Sharma
Sandeep Sharma is offline
Old 19-10-2004, 01:25 PM   #2 (permalink)
could be either.... It might be a faulty OS installation as it runs on other systems...I would suggest that you try to get the latest drivers for your graphics card. If that doesnt work try reinstalling the OS and then the game. As a last resort check with ur vendor to see if its a HW issue....
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 19-10-2004, 08:43 PM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Moniter your Mobo temperature ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 20-10-2004, 03:04 PM   #4 (permalink)
club_pranay's Avatar
your pc is too HOT!! better chack your PC's temp otherwise get ready to buy new hardware.
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 20-10-2004, 03:55 PM   #5 (permalink)
try getting latest chipset and graphics driver for ur motherboard from intel web site ......
and it happens only when u play serious sam or any other games ....if it happens only with serious sam .....then check the copy of seroius sam u have .....if it works fine on others comp .....then definately the problem is with ur comp ......or else its with the game ....!
imgame is offline
Old 21-10-2004, 12:08 AM   #6 (permalink)
I gues no prob with ur CPU temp coz due to this computer get hang,
first check do u have proper cooling for ur AGP or ur MOB if it's onboard Graphic card u r using,
then check for ur graphics drivers guess they r conflicting,
then go for OS prop check through DX,
then check ur OS prop,
Then reinstall all the things.
then right here again
Music is like Sex, The more you get, the more you want.
demoninside is offline
- by Krow
